Does the driver's side window have an Auto up and/or auto down? My sales guy didn't really know, nor could I get it work in the 15 secs I tried playing with it.
Same for all C6s for this question, but if you have questions about anything else on the C6, you need to either mention the year and body style or fill out your profile.
Express-Down Window
This feature is on both power windows. Press the front
of the switch to the second position to activate the
express-down feature. If you want to stop the window
as it is lowering, press the switch again.
You can also add some additional power window functionality by purchasing the Window Valet. It installs in 5 seconds (just plug it into the ODBII port). With it you can 1) remotely (with the fob) lower both windows (to begin cooling off a car that has been parked outside in the sun); 2) remotely raise both windows; and 3) remotely vent both windows (lower both windows about 1/2 inch to let hot air escape while parked).
