Rear End Chatter
Rear axle chatter is a grinding type sound that can be heard from the rear of the car at very low speed while making a turn. Frequently only happens when the differential is cold (as in not warmed up, not necessarily winter type cold). Goes away when differential warms up.
Fix is a change of fluid and additive. If it returns, then they replace the differential clutch packs.
do you mean that GM knows about it and they come with a fix and do you guys have more information do you think i have to wait till my next service or take it now my car have 6000 miles is it very serious???!
Subject: Rear Axle Chatter Shudder On Turns -
keywords bind differential
#PIP3559F - (12/06/2006)
Models: 2004 - 2007 Cadillac XLR
2006-2007 Cadillac XLR-V
1999 - 2007 Chevrolet Corvette, Corvette Z06
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Rear axle chatter or shudder on turns on Chevrolet Corvette and Cadillac XLR.
Recommendation/Instructions:
Flush and fill the rear axle with synthetic axle lubricant GM P/N 89021677 (Canadian P/N 89021678) and appropriate amount of the friction modifier additive P/N 01052358 (in Canada 992694). See fluid amounts listed below.
Note 1: In some cases it has shown that a second flush procedure on a second repair visit will correct the chatter/shudder concern prior to replacement of the clutch packs.
Note 2: To properly flush the rear differential remove the left differential cover and get all of the old fluid out off the differential, wipe out the residue replace the cover o-ring and then reinstall the cover and fill with the appropriate amount of fluid and friction modifier additive.
If the complaint or the condition persists after the flush and fill, replace the right and left rear axle clutch packs following published service procedures.
After clutch pack replacement use synthetic axle lubricant GM P/N 89021677 (Canadian P/N 89021678). and the appropriate amount of friction modifier additive P/N 01052358 (in Canada 992694). See fluid amounts listed below.
Note 3: PRIOR TO INSTALLING THE FRICTION MODIFIER ADDITIVE FOR EITHER OF THE ABOVE REPAIRS THE BOTTLE MUST BE SHAKEN VIGOROUSLY FOR AT LEAST 1 MINUTE TO MIX THE ADDITIVE THOROUGHLY.
Once the axle fluid has been changed the car must be driven in 8 - 10 SLOW figure eights to work the fluid between the clutch plates.
Fluid capacity:
Model Year
Model
Differential Lube
Friction Modifier
1999-2005
Corvette ALL
1.69 qt (1.6L)
4 oz. (118 ml)
2006-2007
Base Corvette
1.95 qt (1.85L)
5 oz. (148 ml)
2006-2007
Corvette Z06
2.70 qt (2.55L)
6.4 oz. (190 ml)
Note 4: Export vehicles use 2.01 l (2.12 qt) synthetic axle lubricant GM P/N 89021677 (Canadian P/N 89021678) and approximately 150 ml (5.1 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
I've changed the diff lube twice and the noise seemed to get worse each time.
Looks like I'm in for a clutch pack change. The car only has 4000 miles on it! This $ucks the big one. I love you GM.
Tom
What he said. dentin11, sounds like you need to find a new dealer. Your is full of
SigArms226, the fluid change is covered under warranty. I had mine done and it did not cost me anything.
