Service Active Handling?!
Pete
I hate the thought and am hoping it will be gone tomorrow...But I do have the rear end chatter so I suppose Ive got to go in anyway..
jke
Here is the link to the illustrated TSB via Alldata
http://www.alldata.com/tsb/General-M...dex-issue.html
Hit control F, and type C0710, or scroll down to Oct 3, and look for TSB 06-02-35-002A. I fixed mine in less than 15 min. Must remove knee bolster to access connector.
jke
For the 2007's, there seems to be quite a few TSB's that address issues popping up on the forum all the time... Anyone know of a free site to access these?
TSB Number & Issue Date TSB Title
06-02-32-013 OCT 06 Power Steering - Diagnostic Tips
06-08-49-020 OCT 06 Instruments - Heads Up Display Bezel Warped
00-06-04-033B OCT 06 Emissions - OBDII I/M Readiness Testing
02-08-98-001C OCT 06 Body - Metal Panel Adhesive Bonding Information
00-00-89-027D OCT 06 Interior - Eliminating Unwanted Odors
04-03-10-001C OCT 06 Tires - Tread Puncture Repair Procedures
05-03-07-009A SEP 06 Wheel Alignment - Recommendations/Requirements
04-03-10-012A SEP 06 Wheels - Pitting/Brake Dust On Chrome Wheels
05-00-89-078A SEP 06 Fuel System - GM Fuel System Treatment Plus(R)
01-07-30-038D SEP 06 A/T - Poor Performance/MIL ON/DTC P0757
00-08-48-005B SEP 06 Body - Distortion On Outer Glass Surfaces
06-08-111-004 SEP 06 Body - Exterior Emblem Discoloration/Peeling/Blistering
06-03-10-010 SEP 06 Wheels - Changing Procedures/Precautions
05-06-02-002A AUG 06 Cooling System - DEXCOOL(R) Leak Detection Dye
03-07-29-004C AUG 06 M/T - Normal Operating Characteristics
00-00-90-002D AUG 06 Tires - Inflation Pressure Information
06-08-50-009 AUG 06 SRS - Occupant Sensing System Precautions
03-03-10-007B AUG 06 Tires - Original Equipment Tire Characteristics
00-06-02-006D AUG 06 Cooling System - Coolant Recycling Information
06-06-04-037 AUG 06 Engine Controls - MIL Function During I/M Testing
00-03-10-002D AUG 06 Wheels Chrome Wheel Chemical Staining/Pitting/Corrosion
05-06-04-022B JUL 06 Fuel System - TOP TIER Gasoline Information (Canada)
06-08-44-012A JUL 06 Navigation System - DVD Disc Update Program
06-01-39-007 JUL 06 A/C - Contaminated R134A Refrigerant
04-06-04-047F JUL 06 Fuel System - TOP TIER Gasoline Information
TSB 06.02.35.002
Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure Wires in SWPS Connector)
2005-2006 Chevrolet Corvette
with Steering Wheel - Tilt, Telescoping (RPO N37)
Condition
Some customers may comment on a Service Stability Message on the DIC.
Diagnosis with a scan tool may reveal a DTC C0710.
Cause
The most likely cause of a DTC C0710 on a vehicle equipped with telescoping/tilt steering wheel is high resistance in SWPS connector C202. Fretting terminal corrosion maybe present in the SWPS connector due to the telescoping motion of the steering column. When the steering column is telescoped in and out, the female terminals within the SWPS connector may move on the male terminals of the SWPS. This movement between the terminals may cause a high resistance condition in the SWPS connector.
Correction
Remove the driver's side close out panel.
Notice:
• Failure to properly tape the wires in the connector may result in additional concerns.
• Failure to use a small plastic strap 2.5-3.5 mm (0.10-0.14 in) in width may prevent the SWPS connector from properly seating, resulting in additional SWPS DTCs.
Using electrical tape (1), tape from the plastic strap up the wires a minimum of 2.5 cm (1 in).
Install a small plastic strap (2) 2.5-3.5 mm (0.10-0.14 in) wide around the SWPS sensor connector so that it retains the wires to the connector as shown.
Important: Install and remove the SWPS connector a minimum of three times to remove any possible terminal corrosion.
Reinstall the SWPS connector.
Reinstall the close out panel.
same on my 2005 and I brought in the TSB number and theytook care of it. No big deal. That's one of the nice things about the information available on this forum. Sometimes stuff happens but it helps you to keep some perspective and not freak out. As I recall, some of the DIY's didn't even bring it in for the warranty fix. Looked pretty simple and they said it just took a few minutes to fix. Sounds like you need you have have them check out the rear end chatter so get both things taken care of at once. Best of luck.
It also could be a sensor or whatever but if you have the telescoping steering I would put my money on that TSB fix.
keywords bind differential
#PIP3559F - (12/06/2006)
Models: 2004 - 2007 Cadillac XLR
2006-2007 Cadillac XLR-V
1999 - 2007 Chevrolet Corvette, Corvette Z06
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Rear axle chatter or shudder on turns on Chevrolet Corvette and Cadillac XLR.
Recommendation/Instructions:
Flush and fill the rear axle with synthetic axle lubricant GM P/N 89021677 (Canadian P/N 89021678) and appropriate amount of the friction modifier additive P/N 01052358 (in Canada 992694). See fluid amounts listed below.
Note 1: In some cases it has shown that a second flush procedure on a second repair visit will correct the chatter/shudder concern prior to replacement of the clutch packs.
Note 2: To properly flush the rear differential remove the left differential cover and get all of the old fluid out off the differential, wipe out the residue replace the cover o-ring and then reinstall the cover and fill with the appropriate amount of fluid and friction modifier additive.
If the complaint or the condition persists after the flush and fill, replace the right and left rear axle clutch packs following published service procedures.
After clutch pack replacement use synthetic axle lubricant GM P/N 89021677 (Canadian P/N 89021678). and the appropriate amount of friction modifier additive P/N 01052358 (in Canada 992694). See fluid amounts listed below.
Note 3: PRIOR TO INSTALLING THE FRICTION MODIFIER ADDITIVE FOR EITHER OF THE ABOVE REPAIRS THE BOTTLE MUST BE SHAKEN VIGOROUSLY FOR AT LEAST 1 MINUTE TO MIX THE ADDITIVE THOROUGHLY.
Once the axle fluid has been changed the car must be driven in 8 - 10 SLOW figure eights to work the fluid between the clutch plates.
Fluid capacity:
Model Year
Model
Differential Lube
Friction Modifier
1999-2005
Corvette ALL
1.69 qt (1.6L)
4 oz. (118 ml)
2006-2007
Base Corvette
1.95 qt (1.85L)
5 oz. (148 ml)
2006-2007
Corvette Z06
2.70 qt (2.55L)
6.4 oz. (190 ml)
Note 4: Export vehicles use 2.01 l (2.12 qt) synthetic axle lubricant GM P/N 89021677 (Canadian P/N 89021678) and approximately 150 ml (5.1 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
