Bad Gas Cap?
Old Mar 25, 2007 | 11:28 PM
niceguy753's Avatar
niceguy753
Default Bad Gas Cap?
So I go to fill my tank...premium was $2.75...so I figure get it before price goes higher. I think I turned too hard to remove the cap. When I went to place cap back on...it won't tighten...it just clicks and will not attach. I can twist all I want , but the cap justs falls off!! Why did it break? Did I do something wrong?
Old Mar 25, 2007 | 11:34 PM
snStarter's Avatar
snStarter
I have exactly this problem. Drives me NUTS.
Vette_DD's Avatar
Vette_DD
Your dealer will probably have to answer that when you go to see him to get a new one under warranty.
Old Mar 26, 2007 | 03:24 AM
web1's Avatar
web1
yeah, they break pretty easy, our dealership was pretty good about replacing them under warrantee
Old Mar 26, 2007 | 02:54 PM
Lightning Coyote's Avatar
Lightning Coyote
Happily have not done this just yet.
Old Mar 26, 2007 | 02:57 PM
KenC6's Avatar
KenC6
Thanks for the "heads up" on the gas cap.
Old Mar 26, 2007 | 04:57 PM
wsharp24's Avatar
wsharp24
I had the same problem. A forum member suggested to lightly pull up on the cap before you turn it to put it on. You will hear it click and it is secure. I first notice this when the DIC said for mte to check gas cap.
The suggestion worked. I use this method every time and it works. Too bad the Chevy folks don't pass on this info. It would save alot of us going to the dealer and a lot of money for GM.
Give it a try...it worked for me.
Old Mar 27, 2007 | 10:43 AM
Frankb10's Avatar
Frankb10
Default Gas cap
Had mine replaced by the dealer under warranty at 5,000 miles.
It would not click and lock. New one came in and it was missing the little plastic stud that holds it in place. Service manager had the mechanic take one off the showroom floor. Ok now....
To Bad Gas Cap?
