Have a stock 07 coupe. We will be on vacation for two weeks without the car. Will the car start on our return - or do we need to connect a charger to ensure it starts?
A well charged battery even on a C6 should make it two weeks. I've gone two weeks with my '05 without problems. With that said, If you have a charger, I'd just go ahead and hook it up. Why risk it and have to deal with the aggrivation upon your return?
You should have no problem at all with that.
Mine sat 3 weeks in 20 degree weather and started right up.
Stop worrying and enjoy your vacation.
I would take it out or put on a tender. My battery sat for a couple months in Minnesota over the winter and froze solid. I had to bring it into the dealer and get it replaced. Those OEM batteries are junk.
I've never disconnected the battery for vacations. I don't have a tender either. Longest time was just over 3 weeks, and it fired right up like I never left.
It's not the battery it's the car. If your car doesn't have a drain problem, it will be fine. If it has the DBS drain problem it will be dead in a few days. A dead battery will freeze, a charged one will not.
Ask the dealer if your VIN falls in the dead battery bulletin VIN range where they are reprogramming. If it doesn't I wouldn't sweat it. If it does, get it reprogrammed at the dealer or leave it on a Battery Tender until you get a chance to get that done.
That is one of the huge mistruths about these cars that they have junk batteries. The batteries are fine, it is that some cars have way too much parasitic drain and kill the battery. So many people put in real expensive batteries and constantly leave them on a charger. That is kind of a band aid solution and not really fixing the problem of excessive parasitic drain which is what the bulletin for reprogramming fixes.
the above should not be a problem with 07, the important word there is "should", according to the DVD included when you bought the car it recomends disconnecting battery negative terminal and putting a trickle charger on if you are not going to use car for more than 25 days, I think that is their way of saying if you let it sit for a month, there is a possibility of battery going dead. i wouldn't think 2 weeks in the weather we are now having should be a problem.
The guideline for the C6 is 28 days (starting from a full charge).
I've had to battle this problem and have had the car into the dealer several times. Last visit I asked for the newest flash and was told I didn't need it. They noted on my workorder that the car has a 16 milli-amp drain and that it is within spec. I'm guessing that that will drain an Amp every 60 hours. How long should it last before not starting? The car has gone 7-10 days at times and still started and other times only 3-4 days (or less.)
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
--Dan
Back of the napkin tells me it 0.016 amps should last about 4 months. That's less than a fifth of a watt. Trivial.
That's interesting. The dealer disconnected my GPS theft device saying that its 100 milli-amp draw was the cause of all my problems and would drain the battery in 3-4 days max -- although I've had it since new 14 months ago. The math doesn't support their statement. But, so far the car has been starting so I don't have an answer. They are also saying that repeated short trips to work (10 minutes) will not sustain a full charge and will gradually (within a week) weaken to the point of not starting.
I really don't think our cars should need to be on a tender when driven almost daily or left to sit for a week or two. None of my other cars need this crutch.
