Need Help With Check Engine Light
Old Mar 27, 2007 | 11:07 PM
NewToC6's Avatar
NewToC6
Default Need Help With Check Engine Light
I recieved the check engine light. My friend hooked up his OBD-II and scanned the code PO455 Evaporative Emissions Control Fault - Major leak. I traced it down to the fuel cap. He re-set the light. Now I'm wondering if something is wrong now since the light does not even come on, Not even when the car first starts. Is it possible that I did something wrong. The OBD manaul said to turn on the ignition. I did start the car with the OBD connected because I did not know how to just turn on the ignition with a push button start. The OBD would not scan in the Accessory mode. Any help, thoughts or comments would be appreciated.
Thanks in Advance.
Old Mar 27, 2007 | 11:17 PM
keith5's Avatar
keith5
Active Streak: 90 Days
Had similar.. Although, I used OnStar. They had me reseat the gas cap. They suggested bad gas. It was and I have not had a Check Engine light since.
Oops, forgot to mention that I only use Amoco Ultimate - from a new service station.
In the problem above - I filled up at an old station in the sticks....'Nuff said
Old Mar 27, 2007 | 11:29 PM
shopdog's Avatar
shopdog
Thanks in Advance.
To put the car into ignition on engine off mode, press and hold Accessory for 10 seconds. The dash will come alive, you'll be able to read DIC parameters, and your OBDII scanner will be able to retrieve codes. To get back into RAP mode, just push the lower half of the start switch again (a simple tap will do). If you don't go back to RAP, the car will not time out and it'll drain your battery.
Oh, BTW, you didn't do anything wrong. It is Ok to scan the car with the engine running.
To Need Help With Check Engine Light
