Squeaky roof fix ?
Old Mar 29, 2007 | 04:06 PM
BOBBYV's Avatar
BOBBYV
St. Jude Donor '07
Default Squeaky roof fix ?
Hi everyone, I have a very annoying squeaky noise coming especially from the left side of the transparent top. I tried oiling the seals with lithium grease but no help. Any other tips ? Thanks !
Old Mar 29, 2007 | 04:09 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
There is a TSB that you dealer should have to replace the plastic guide and striker. The TSB is TSB# 05-08-59-003B. See this thread for some detail of the fix:
http://forums.corvetteforum.com/show...light=roof+tsb
Paul
Old Mar 29, 2007 | 04:31 PM
Big Lebowski's Avatar
Big Lebowski
I got the squeeky roof also on my 2005 coupe, as I take my top of several times a day on a nice day.
I found a way to completely eliminate all coupe roof squeeks that also makes taking the top on and off much easier. The fix is replacing the squeeky coupe with a new convertible. Problem solved!
No more squeeky roof, guaranteed!
Old Mar 29, 2007 | 05:07 PM
BOBBYV's Avatar
BOBBYV
St. Jude Donor '07
Is that TSB for 2007's as well ?
Old Mar 29, 2007 | 05:22 PM
talon90's Avatar
talon90
NCM Ambassador
Not originally. It was out for '05's. I'd like to believe that they incorporated the fix from the factory for the '07's. Sorry 'bout that, I couldn't tell that you had an '07 as you didn't fill out your profile.
Old Mar 30, 2007 | 10:38 AM
carjon's Avatar
carjon
Got to tell you I had the fix on my 05 and the sweaking and poping sounds are back.
Old Mar 30, 2007 | 11:36 AM
footba4672's Avatar
footba4672
I also have that issue on my 07. I'm going to the dealer on monday. It was fine for the first 2000 miles and all of sudden started squeeking on the left and the right side toward the rear of the window. I will let u know what they say..
Old Mar 30, 2007 | 11:42 AM
Hoonose's Avatar
Hoonose
Silicone grease and spray to all mating surfaces, guides and pins. Has worked for my 3 roofs C5 and 6.
I also found that lowering the front roof edge as far as it will go helped C5 and 6 noises.
Old Mar 30, 2007 | 11:55 AM
footba4672's Avatar
footba4672
what kind of spray???
Old Mar 30, 2007 | 11:58 AM
Hoonose's Avatar
Hoonose
I use a pure silicone spray.
Old Mar 30, 2007 | 02:18 PM
baddasp's Avatar
baddasp
Seems to work for two or three days and then it always comes back. What an annoying POS.
Old Mar 30, 2007 | 02:33 PM
07slvrbullet_z51's Avatar
07slvrbullet_z51
Make sure you fully engage the rear roof latch. I had the same problem today. Even though the rear roof latch looked engaged, I pushed firmly on the rear latch then heard a click. I must have not pushed hard enough when I first engaged it. No more creaks.
Old Mar 30, 2007 | 03:17 PM
C64BOB's Avatar
C64BOB
Try this tap the window button and lower the windows off the stops (which are screwheads) say 1/16 of an inch. This stops all the noise in my car and since the windows are side-sealed you don't get an increase in wind noise either.
To Squeaky roof fix ?
