convertible leaks?
Old Mar 31, 2007 | 09:41 AM
Nueboch's Avatar
Nueboch
Default convertible leaks?
looking at the owners manual I saw a warning against using high pressure washes which could cause the top to leak. Any Vert owners having problems like this or have any advice to offer about this issue?
Old Mar 31, 2007 | 09:50 AM
Scruff Vette's Avatar
Scruff Vette
Ignore it. As long as your windows are full up, it is leakproof. I've been through extemely heavy downpours and also regularly through "laser Car Washes" that use high pressure, high volume and never had a single drop come in.
Old Mar 31, 2007 | 09:55 AM
Nueboch's Avatar
Nueboch
Thanks, that's what I wanted to hear. The concept didn't make a lot of sense to me considering one should be able to run down the interstate in the rain. That would put a lot of pressure on the top as well. I've had zero problems with my C6 coupe using a high pressure wash and had planned on using same cleaning routine with the Vert.
Old Mar 31, 2007 | 09:58 AM
Big Lebowski's Avatar
Big Lebowski
Also keep in mind that the manual tells you to obey the posted speed limit and all traffic signals.
Everything I have read claims these tops to be waterproof. Over time I'll believe it if i see it.
Old Mar 31, 2007 | 10:03 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Never had a problem, but I wash it by hand.
Old Mar 31, 2007 | 10:05 AM
Nueboch's Avatar
Nueboch
While I had not planned on using the power wash point blank on the top, I had planned on backing off, soaping it down, using a brush and rinsing it off. I tend to be more agressive with the body. I've always been a little careful around the seals on the windows and coupe top, never had a drop of water get into the car. Now I'm planning my strategy for a Vert which is currently in transit, I'm very impatiently waiting.
Old Mar 31, 2007 | 10:12 AM
ProfMoriarty's Avatar
ProfMoriarty
The C6's graceful curves should be caressed with a washing mitt and rinsed with a hose without a nozzle... not blasted like a mildewed deck.
Old Mar 31, 2007 | 10:15 AM
Nueboch's Avatar
Nueboch
I always wash mine late at night, stealthily, trying to avoid the Corvette police
Old Mar 31, 2007 | 10:37 AM
bradb's Avatar
bradb
St. Jude Donor '06-'07
Only leaks I get are when I open the window or door when it is/has been raining and the water drops onto my left leg from that badly designed area near the windshield frame. I don't know if coupes leak there, though. Pretty nice power top I think. Chevrolet.
Old Mar 31, 2007 | 10:41 AM
Vettlldo's Avatar
Vettlldo
Wash it in the garage with the door down that will keep 'em wondering.
Old Mar 31, 2007 | 10:54 AM
Nueboch's Avatar
Nueboch
Coupe does the same thing but I don't consider it a bad design. Just part of the stealth package.
Old Mar 31, 2007 | 11:03 AM
bradb's Avatar
bradb
I can always say my C6 makes me damp.
To convertible leaks?
By Michael S. Palmer | 2026-06-03 11:00:24
