Trick for no buzzer with door open
Old Apr 1, 2007 | 08:14 AM
heisnuts's Avatar
heisnuts
Default Trick for no buzzer with door open
Have any of you run into the problem of the door buzzer going off when working on the car with the accessory power on (to run the radio) and the drivers door open?
When I am washing or detailing the car I like to have the radio on but do not like the buzzer going off when the drivers door is open. The solution is to manually click the door latch closed (the latch actually on the driver door) and the car thinks the door is closed and the buzzer stops. You will have to open the latch before you try to close the door and this is easily done by pushing the door open button on the door panel.
Old Apr 1, 2007 | 08:27 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Nice idea, I usually just open the windows and leave the door closed but this is a nice option if the door needs to be open.
siffert's Avatar
siffert
Thanks very much for the tip!
Old Apr 1, 2007 | 09:05 AM
gilly6993's Avatar
gilly6993
St. Jude Donor '08
great tip....thanks!
Old Apr 1, 2007 | 09:33 AM
johnodrake's Avatar
johnodrake
Moderator
Never thought of that!
Viprklr's Avatar
Viprklr
On manual cars you can hit the start button without engaging the clutch and it will not beep when the doors are open. I am assuming you can do the same with an automatic if you don't step on the brake when hitting the start button. Remember don't hit the accessory power, hit the actual start button.
This problem bugged me for a year. Finally figured it out one day.
Matt
Old Apr 1, 2007 | 11:19 AM
shsirish's Avatar
shsirish
Ok, Lets say I forgot to open the latch and slam the door shut! There goes the latch??
Old Apr 1, 2007 | 12:12 PM
KENZ51's Avatar
KENZ51
Dont Slam the Door! actually its not that weak, im sure if you were trying to bust it, it could be done, but not under norm. press.
Old Apr 1, 2007 | 12:25 PM
keg's Avatar
keg
Great idea I'll be using this next time I need the drivers door open while working on my car. Thanks
Old Apr 1, 2007 | 12:28 PM
C6FirstVette's Avatar
C6FirstVette
When I was at BG looking at my Vette being assembled one of the Q control guys told about this little trick BUT don't forget what you have done since you can jamb the latch if you shut door without returning to normal position.
Michael
Old Apr 3, 2007 | 02:48 PM
Viprklr's Avatar
Viprklr
Matt
I have verified that if you hit the start button without engaging the clutch you can have the doors open without the beeping. Can anyone confirm this is also possible with and auto?
Matt
To Trick for no buzzer with door open
