HELP, Need Tires
Time to replace my F-1 EMT's. Considering Mich PS2's. Tire Rack rates a Bridgestone Potenza higher (#1) than the PS2's much to my surprise but that may be reviewer bias to another car. Don't know how much to trust their charts. (my supercar EMT's rated way low)
I like the non-runflat with latex sealing compressor approach. Still open minded on that though. Was nearly settled on PS2's from reading until found that TIRE RACK won't offer a road hazard (my OEM's actually have about 2K left but one also has a non-repairable nail in the sidewall).
OK, Let me have it, ...opinions, new thoughts? (I did a thread search)
Also having trouble finding someone who will mess with corvette rims and TPMR's.
Speaking of tire life, the RE050s have a pretty soft compound. The PS2s have a dual compound - softer on the outside. The KDWs have a high-silica compound that sticks well and wears well. For me, that means around 10K miles on a set of RE050s, 15K on the PS2s and 20K on the KDWs. Your milage may vary.
As far as driving the tires, the RE050s are pretty easy. The PS2s may take a little more getting used to, or did for me. Part of that was just making myself believe how well they stick, and with how little fuss. A bit like the C6 in that respect; they just go where you point them, without complaining. Of course that seems like a lack of feedback to many people, and did to me at first. After getting used to it, its not a problem.
Tire Rack has a list of installers in your area, with some information and ratings by customers. Probably a good place to start. Some installers don't like messing with runflats, but I think that's more putting them on than taking them off. At least that's what my installer said.
Tom
AFVETTE: I'll put those on the list as well as KDW's "BASSVETTE"
I think the Bridgestones are probably the closest to the original Supercar tires, a soft compound, fairly "square shouldered" tire. I replaced them at 13.5K, but probably should have done the fronts at about 12K - they were pretty well gone! I could have gotten another couple thousand out of the rears.
The KDWs are probably more comparable to the original non-SC tires, at my best guess. A little harder compound, better wear, but still excellent handling.
But the most direct comparison I have is the GY SC EMTs to the PS2s on the C6. The PS2s are a lot easier to live with - quieter, ride better, almost immune to the "tram line" effect, and better in cold weather. They seem to work well in the rain, based on limited experience - although the GYs worked surprising well in rain for a summer tire. So far, they are wearing more evenly.
Of course, they'll be harder to live with if I get a flat! I got the Conti Comfort Kit from the Tire Rack, which seems to be well thought out. Of course I'm hoping not to ever use it, but ...
As far as performance, the OEM tires are good, but the PS2s seem to do better. I haven't done timed laps with both tires, but on a few corners I'm very familiar with my exit speed is up a bit.
One thing I should mention about the PS2s. They're a little more round-shouldered, I think, so they look slightly narrower than the original tires - or perhaps just a little less agressive. Don't know if that matters to you or not.
Duh. Could have re-read the first post and seen that you're talking about a Z51 too. Oh well.
The downside is that the sealant has a four-year shelf life, then the cartridge must be replaced. Of course the other stuff probably has a limited useful life too.
Haven't tried it myself, but they seem to think they've addressed the sensor problem. The question remains if this is more trouble than simply using a plug kit, which isn't that difficult.
