07 Vert Problem
Old Apr 12, 2007 | 09:25 PM
Jaws12's Avatar
Jaws12
Default 07 Vert Problem
I was just on vacation for 10 days and came home this morning. Started up the new Vert and went for a ride. Driving down the highway I opened the window partially and started going over some bumpy pavement. I heard a strange noise, somewhat like a twisting noise, and put the window up. Now there is a rattle or vibration or squeak in the driver's window only when raised.
The window is still indexing properly, but when down or slightly cracked open the noise completely stops. When the window is up and fully closed the noise returns.
Any ideas???
Old Apr 12, 2007 | 09:30 PM
VET4LES's Avatar
VET4LES
I think a trip to the dealer is necessary.
Old Apr 12, 2007 | 10:17 PM
jjohn918's Avatar
jjohn918
Very interesting. Not exactly sure what would be the cause of it.
Old Apr 13, 2007 | 06:41 AM
JVM225's Avatar
JVM225
St. Jude Donor '06
Old Apr 13, 2007 | 07:38 AM
Hound's Avatar
Hound
sounds like its made by air flow,,try opening the other window and see if it stops. try opening and reclosing the top to see if it was sealed good.
Old Apr 13, 2007 | 07:51 AM
greenie99's Avatar
greenie99
Airflow with the window CLOSED?
Old Apr 13, 2007 | 07:54 AM
greenie99's Avatar
greenie99
Any ideas???
When the window is up, the bottom of the glass frame pulls on the inside door panel. When you move the window down, this bit of pressure is released. Maybe if the dealer removes the door panel and re-seats it your noise will disappear.
Old Apr 13, 2007 | 08:03 AM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I have a similar problem with my '06 vert. It started after the dealer checked the door panels for excessive vibration from the Bose speakers. The noise seems like it is coming from the door itself, but only when the window is up all the way.
Old Apr 13, 2007 | 08:18 AM
Hound's Avatar
Hound
YES ,, BUT IS IT ?
Old Apr 13, 2007 | 08:41 AM
rjr2007's Avatar
rjr2007
warranty work
Old Apr 13, 2007 | 01:06 PM
wayback's Avatar
wayback
same here but more noticable when outside temps are low(40s).
Old Apr 13, 2007 | 10:56 PM
UneasyDriver's Avatar
UneasyDriver
Maybe time to trade it in for something newer
Old Apr 13, 2007 | 11:42 PM
Jaws12's Avatar
Jaws12
Hey Uneasy driver, I think I know who you are!!!
In fact, I did trade it in today.
I fell in love with a Monterey Red Coupe!!!!!!!
But you know that already.
Old Apr 14, 2007 | 12:05 PM
Lightning Coyote's Avatar
Lightning Coyote
Old Apr 17, 2007 | 12:26 AM
frankz06_cf's Avatar
frankz06_cf
Default silicone grease
I just noticed this same problem on my new coupe which only has 2,700 miles. It kind of soon for it but it has gone through very cold weather in Kentucky and now hot weather here in Miami.
When I drive over bumps the driver's window squeaks, if I lower the window and drive over the same bumps it does not squeak.
I checked the owner's to see if it could be related to the weatherstripping and it does seem to be that. Check out page 411 "Weatherstrips".
I also did a search on yahoo for this problem and found a post on a BMW forum were someone had this same exact problem, applied silicone grease and it went away! I'm getting some this week.
Old Sep 10, 2007 | 06:27 PM
robl45's Avatar
robl45
well is the problem fixed?? I think I may have the same problem.
Old Sep 16, 2007 | 02:49 AM
briancuss's Avatar
briancuss
It must be a common problem, my 07 Vert does EXACTLY the same thing. It really bugs me, so I'll share any info if I can find the fix. I too think the source is the weatherstrip - maybe I can lube it without too much of a mess.
To 07 Vert Problem
Old Sep 16, 2007 | 03:18 AM
robl45's Avatar
robl45
I'm still trying to find spray silicon lube local to me, auto parts store didn't have it.
Old Sep 16, 2007 | 06:19 AM
Jus Cruisin's Avatar
Jus Cruisin
I don't think Jaws gives a flip about the noise anymore.
Old Sep 16, 2007 | 08:24 AM
briancuss's Avatar
briancuss
I wonder if petroleum jelly (Vaseline) would quiet the squeak with the weatherstirp?
