Normal Battery Voltage?
Tonight its beautiful out so i take the roof off, hop in, and click click click. Ended up having to jump the car off of my dd and i'm wondering if its going to start in the morning. Giving me all kinds of nasty messages before cranking such as no fob detected, service car soon, etc. After getting it running the battery at idle was ranging between 13.3 - 13.8 and 14 tops while giving the car gas.
I thought DBS was only on '05s?
He made me nervous so I put mine on my smart charger. I'm pulling 2.2 amps. I drove it yesterday. I'll check it in a couple hours.
So reading below about 13.8 V indicates that your battery isn't being charged. Readings between 13.8 and 14.4 V indicate normal charging. Reading about 14.4 V or a little more indicates a fully-charged battery. These numbers can vary a bit due to temperature and the accuracy of the meter.
So if you're reading around 14.1 V either your battery needs a fair amount of charging, or there's a problem of some sort that's not letting it get fully charged.
I'd fully charge the battery (overnight on a "smart" charger) then take a nice drive. Readings around 14.2 or so for the first 10 - 15 minutes are normal, but after that your voltage should be pretty close to 14.4 V. Much more or less indicates a problem.
Of course these readings should be taken with the engine running fast enough to provide charging current - say at least 1500 RPM.
Was your door locks in passive mode? Tell the dealer to look up that bulletin, I think you may need the programming.
Normal voltage is 2.1 Volts per cell - stand alone/car off. So right around 12.5 to 12.7 V or so. Running it's going to be a couple volts higher indicating it is charging, you'll see 13's to 14's Volts running.
Accessory mode, engine off is could be in the low 11's with all the systems on but no charging.
You just never know when.
Now if you saw 11.8 at the battery with a separate hand held volt meter with everything completely off, then I'd think you have a low charged battery. Everything off, you should see mid 12's at the battery. You can't read it that way through the DIC, so many people do get concerned when reading it through the DIC. You just have to realize when the DIC is on in acc mode, so is a lot of other stuff and it is normal to see voltage in the 11's/high10's.
Trickle charger is a great idea for anytime the vehicle will sit for more than 2 weeks. If it can't last 2 weeks without going dead, something is wrong.
One more thing is when you open the door to pop the hood the interior lights go on. I wait a few minutes for them to go off and the battery settle down before checking it with a volt meter.
The voltage reported by the DIC is the voltage measured at the engine by the ECM. So if the voltage reported on the DIC is low, voltage at the engine is low too, and that indicates either an actual low battery or a problem with the wiring between the battery and the engine/ECM. Usually, the latter will be a loose or corroded ground connection, though a high resistance in the hot primary wiring is a possibility too. This is a problem, and will show up as poor starting, running, and battery charging performance.
Remember that to read battery voltage via the DIC the engine must be off. Hold accessory for 10 seconds to put the car in ignition on engine off mode to make the reading. When the engine is running, you are seeing charging system voltage, not battery voltage. A healthy charging system will show a voltage on the DIC (with the engine running) of between 13.8 and 14.4 volts. The higher voltage means the charging system is trying to charge the battery. After the battery reaches full charge, the running DIC voltage should drop to 13.8-14.2 volts indicating the car's charging system (regulated by the ECM) has determined the battery is fully charged and is maintaining only a float charge on the battery. (A higher voltage on the DIC means either the battery isn't yet fully recharged, or there is a problem with the primary wiring, or the charge regulating circuit in the ECM.)
One of the electrical issues with the Corvette is that the minimum required operating voltage for the computers is close to the normal full charge voltage of the battery. A battery voltage of less than 11.5 volts will cause the computers to go wonky, throwing spurious codes and operating erratically. That represents a battery with 47% charge.
Of course starting batteries are never supposed to be discharged below 80% charge. They can be damaged if they are (deep cycle batteries can stand being taken down to 20% charge). But folks who don't drive their cars frequently or long enough to fully recharge their batteries are going to have issues even if the car's battery and charging system are operating perfectly normally. If there is a problem, sulphated battery, higher than normal primary circuit resistance, ECM voltage regulation problem, etc, then the issues can be severe.
The best defense against battery problems is to drive the car daily, and drive it at least 30 miles (half an hour) between starts. This lets the charging system keep the battery near full charge. If you can't or won't do that, then you might consider a battery tender. You also want to keep the wiring in top shape, check connections frequently for signs of looseness or corrosion. Correct any problems as soon as they are discovered. This will go a very long way toward eliminating battery related complaints.
