Where did I go wrong?
Are you on runflats or drag radials with that kind of power?
You just need to learn your car a little better. Many guys that get bad run timees or races due to situations like you describe is because they need to learn the characteristics of their particular car. A Corvette is a great car, but that doesnt mean you can just get in, pound the throttle and hold on...especially with all that extra power you are running. You have to practice launching, shifting braking etc on different road surfaces so you know what the car will do and when you push it to the limit. Once you get the feel of when the tires will break loose, when the car has its best pull etc, then you know how to run it.
I dont have a Auto, but I had to relearn throttle feathering with my MN6, especially after the mods I did. I can light the tires in 1-4 way too easily, so I had to learn just the right amount of the throttle to keep accelerating instead of spinning. Once I toast these tires, Ill probably add the widebody kit and wider non run flats to help hook a little better.
Dont fret it....You did good...You did the smart thing and didnt push it. You might have wrecked the car or yourself. Learn your car and it's new power a little more, get ready and go back and kick his tail. It'll feel twice as good!
Do yourself a favor and invest in a set of drag radials if you intend to drag race it. There are several advantages:
1. Better launches/60ft times, well heated less chance for them breaking loose on the 1-2 shift, which BTW could have resulted in you ending up into the wall. I have seen it happen to a bone stock C5 on runflats making considerable less power than you are.
2. Less wear on your street tires.
3. More consistent results.
4. Easier to heat up. Softer compound.
And many others.
I'll go one step further and speaking after nearly putting my own C5 into the wall at Quaker City trying to race it on street runflats while it was making around 330 at the rear wheels with 3.42 gears, KOOKS headers, and a torque converter.
If you are a beginner and have that kind of power, I wouldn't even attempt to drag race that car on those runflats. If you are a beginner and those runflats break loose on you and the rear end starts acting up, and you lift, you could very easily end up having a bad day.
