XM Receiver
Old Apr 16, 2007 | 10:56 AM
tluck's Avatar
tluck
Default XM Receiver
What is the best way/method to install a XM receiver in my 2006 C6 2LT
Coupe?
Old Apr 16, 2007 | 11:13 AM
not08crmanymore's Avatar
not08crmanymore
Have a professional do it??
Old Apr 16, 2007 | 11:33 AM
MNVette's Avatar
MNVette
I guess the first question that comes to mind is, if you wanted an XM receiver in the car, why didn't you just have it installed at the factory? The XM stuff would then automatically appear on the factory radio, and you wouldn't have to have a second unit now.
Since that horse has already left the barn, you can certainly get XM installed, but now you will have to have a couple of additional items put in. First, you'll need an antenna, which will now be external instead of the internal antenna that would have come with the factory unit. The only place you can put an external antenna on the C6 is where the antenna went on the 2005 model - on the bar between the roof panel and the back glass (your wire will most likely tuck into the crack where the glass meets the bar). You'll also need a receiver box stashed somewhere in the car and a display unit to show the programming, controls, etc. Given the nature of the C6 dash, I have no idea where you'll put the display unit - maybe some kind of arm glued or attached to the dash? The stock stereo will have to be pulled and all the wiring done. There might also be a "transmitter" type XM system that doesn't require wiring - it just broadcasts the signal to a station on the radio. Anyway, it will run you about $150-$200 for the stuff and about that for an install (unless you get a free deal at Besy Buy or something?).
Old Apr 16, 2007 | 11:44 AM
tluck's Avatar
tluck
Thanks for the info.
Old Apr 16, 2007 | 11:52 AM
not08crmanymore
COST ME 150 BUCKS FOR THE UNIT installed at an audio place.Plays thru a preset station on the stock radio.
To XM Receiver
