Cags...
Old Apr 20, 2007 | 09:18 AM
Farley's Avatar
Farley
Default Cags...
I have a 07 6sp, Z51 manual on order and I am reading more about CAGS but don't quite understand how it actually works.
This is my first vette and when I test drove it I did not punch it and was able to shift into 2nd and 3rd.
Did CAGS electronically change me to 4th and not 2nd?
Please fill me in.
Thanks.
Farley
Old Apr 20, 2007 | 09:21 AM
runutzzzzz's Avatar
runutzzzzz
Congats on the order!
It actually blocks 2nd so when you pull the shifter down it slides it to the right into 4th! I think you have to be less than 20% throttle and under 15MPH? Someone will come in and tell you the right info!
Old Apr 20, 2007 | 09:22 AM
Michrider's Avatar
Michrider
Only in very specific throttle and load conditions will it force a 1 to 4 shift. It will very rarely ever happen and easy to disable. 50 cent resistor from Radio Shack stuck in the CAGs connector.
Old Apr 20, 2007 | 09:23 AM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
CAGS (Computer Aided Gear Shift) has been around since the C4 on the Corvette. If you try to shift under approx 1,800 RPM, a solenoid will lock out the second gear gate and force you to shift into 4th gear.
There are several ways to defeat CAGS. You can buy a CAGS defeater, pull a fuse or just accelerate above 1,800 RPM. I never bothered to disable it on my C5 because it just didn't bother me. For alot of people it's a "mental" thing.
Old Apr 20, 2007 | 09:31 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As Doughan indicated the Computer Aided Gear Selection has been around for a while. The shift pattern that it is designed to emulate is specific to the automakers testing for its Corporate Average Fuel Efficiency number (CAFE requirement) The automakers are given a set pattern of driving that the car must be tested under. The CAGS is solely to aid their overall average fuel econonmy and avoid a gas guzzler tax. The circumstances in which it will operate are very specific:
One-to-Four Shift Light
(Manual Transmission)
When this light comes on,
you can only shift from
FIRST (1) to FOURTH (4)
instead of FIRST (1) to
SECOND (2).
You must complete the shift into FOURTH (4) to turn
off this feature. This helps you get the best possible
fuel economy.
After shifting to FOURTH (4), you may downshift to a
lower gear if you prefer.
Notice: Forcing the shift lever into any gear except
FOURTH (4) when the 1 TO 4 SHIFT light comes
on may damage the transmission. Shift only from
FIRST (1) to FOURTH (4) when the light comes on.
This light will come on when:
• The engine coolant temperature is higher than
169°F (76°C),
• you are going 15 to 19 mph (24 to 31 km/h) and
• you are 21 percent throttle or less.
Old Apr 20, 2007 | 09:35 AM
JVM225's Avatar
JVM225
St. Jude Donor '06
Drive the car for awhile before you worry about it. I've gotten used to the car and CAGS almost never kicks in.
Old Apr 20, 2007 | 09:46 AM
Farley's Avatar
Farley
Thanks for all the info. I almost never shift below 2500 RPM's in my 96 Mystic Cobra so this should not be a problem and if it is I will just buy a CAGS eliminator.
The wait is killing me on my order, not supposed to get my AO vette till end of May/Early June. It's driving me up a wall.
Farley
Old Apr 20, 2007 | 10:23 AM
User 020720's Avatar
User 020720
If it becomes a bother you can always disable it via a tune. That's what I did. Or you can spend $20 and get the plug in harness eliminator. But there was a post yesterday saying you can remove the MAN TRAN SOL fuse which will also turn it off. Not sure about the validity of that claim so don't hold me to it. You can always drive it like you stole it and CAGS will never kick in. Unfortunately for me I live in a downtown area so that becomes next to impossible.
Old Apr 20, 2007 | 10:30 AM
Vette_DD's Avatar
Vette_DD
All 3 owner's manuals (2005, 2006, 2007) say that fuse is for manual transmission solenoids. Hopeful owners really need to wait to see if it also disables the accidental shift to reverse solenoid.
Old Apr 20, 2007 | 10:36 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Yeah, I agree...Simply pulling the fuse, or unplugging the transmission harness will stop the CAGS from forcing the 1-4 shift under certain conditions, but either of those will probably cause you to get the check engine light (not 100% sure about the fuse).
Buy the CAGS eliminator from PFYC (Forum vendor, best price, cleanest design, reliable part), install and be done with it...unplug the solenoid harness to disconnect solenoid, and plug in the eliminator connector ends at the harness and the transmission receptacle (keeps receptacle clean if you want to restore CAGS in the future). The eliminator provides enough resistance to the circuit to make the PCM diagnostic think the harness is still connected.
Old Apr 20, 2007 | 11:04 AM
not08crmanymore's Avatar
not08crmanymore
It works like this:
1) start the car
2) use your right foot to hit the gas pedal higher than required rpm and problem solved for free.
Old Apr 20, 2007 | 11:30 AM
Carnac's Avatar
Carnac
I think it depends on where you drive. I drive in Las Vegas and where CAGS was a problem is in this example:
I am in a double left turn lane in a line of traffic that crosses a couple of lanes of traffic and goes up a slight incline to cross over a freeway. I start in 1st, I'm watching the signal light, the traffic and car/truck beside me, I am going about 15-20 mph and shift. CAGS kicks in and now I'm in 4th, traffic slows a bit and I'm on an up-hill. Now the engine bogs down some (the low end torque of the C6 is awesome). Now I have to shift to 2nd or 3rd, and the whole process is just not as smooth as I'd like.
I got one of the CAGS eliminators for $20, took 5 minutes to install, and never have to worry about getting 4th when 2nd is what I want.
The CAGS shift (1st to 4th) can/will improve your gas mileage. You can avoid th CAGS shift with speed, throttle, and RPM - but running around town in traffic at 2500+ RPM just isn't necessary.
One way to look at it - I paid for all the engines RPM from 700 idle to 6500 red line - I want to be able to use any RPM that works for the current situation.
Cheers - Jim
Old Apr 20, 2007 | 12:00 PM
User 020720
I live in downtown Dallas and in my case CAGS became such a pain in the a$$ that I needed to turn it off. Normally for all my other driving it would have never become an issue.
To Cags...
