do i need a new windshield?
Old Apr 22, 2007 | 12:54 AM
sealionbeast's Avatar
sealionbeast
Default do i need a new windshield?
I took a rock to the windshield and now I have a small chip in the glass. Do I need to replace the windshield? There are no cracks, just a chip.
Old Apr 22, 2007 | 01:21 AM
Radical05's Avatar
Radical05
Can you live with a chip as there will be more? If not pay and replace it and wait for the next one.
Old Apr 22, 2007 | 01:23 AM
sealionbeast
I guess I should rephrase, do I need to repair the windshield or is it ok to leave chips. I don't want to end up having to replace the windshield.
Old Apr 22, 2007 | 01:45 AM
User 020720's Avatar
User 020720
Glass repair companies can do a good job repairing it to where only you will know it's there. If they can repair it, let them. For one it'll keep the chip from possibly spreading. Depending on your climate, heat can do a number on a chip that's been left alone. But if it's a small knick type chip those are considered normal wear and tear. Over time your windshield will eventually get peppered with them in more than one place. Some will argue it's because these cars are so low to the ground, which I'm sure doesn't help. But my last car was riddled with little knicks everywhere in less than two years. It was a lot higher than the Vette. I think it's just being at the wrong place and the wrong time, like being behind an 18 wheel gravel truck, etc.
Old Apr 22, 2007 | 01:53 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I feel your pain..I have the same thing....right where the HUD display is... its small but I still see it everytime I drive the car
Old Apr 22, 2007 | 01:54 AM
sealionbeast
I think the car being so low does have something to do with it. I also have a black coupe and I only have 3000 miles and 3 chips in the hood and 2 chips in the windshield. I did do museum delivery though and drpve back to California. How is your black coupe holding up? Any chips or dings on the hood or bumper? I had an 05 Mustang for 2 years and nothing, traded it in for the vette and all of these chips in 3 weeks!! Not complaining just curious if its bad luck or happening to others.
Old Apr 22, 2007 | 02:56 AM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
I had a chip (not a nick) repaired and you can't see it. My insurance covered the repair for free as most do.
Old Apr 22, 2007 | 09:28 AM
heisnuts's Avatar
heisnuts
At the very least I would have it repaired for a couple reasons (check with your insurance as they might even cover the entire cost). First of all the chip might not be visable after the repair and second, there is always a chance of the chip spreading into a big crack if left alone.
You can still replace the windshield later if you find you are not happy with the repair, but i would try the repair route first before putting in close to a $2,000 windshield.
Old Apr 22, 2007 | 09:57 AM
Modshack's Avatar
Modshack
$10 Chip repair kits are available at most auto supply stores. They can do a Fair to excellent job minimizing the damage depending on the chip.
I've had both good and bad results depending. Worth a shot. Just fixed one on the wife's Element and it virtually disappeared.
Old Apr 22, 2007 | 10:06 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
For about $45 one of those mobile glass places came out and took care of my C5 in my parking lot at work. I had a good stone chip the size of a dime right in the drivers side field of view. The repair consists of drilling a hole in the chip down to the safety laminate in the center of the windshield glass (two layers of glass and a thin layer of poly to keep the glass fragments in the event of an impact). They will then fill the hole with a two part clear epoxy using a little machine that heats the area and applies a slight pressure to force the epoxy into the crack. It becomes almost invisible when they are done. I would suggest this as in colder temps, your chip can start to form a crack or series of cracks (spider web) and then you will need to replace the windshield. This will likely prevent that from happening.
Old Apr 22, 2007 | 10:46 AM
Sven's Avatar
Sven
St. Jude Donor '08-'09
I'm with Paul. Where it really benefits is keeping water out ... freezing water will expand and crack the windshield; moisture trapped and exposed to high temps will produce same effect. Have had success with this type of repair on three vehicles.
Old Apr 22, 2007 | 10:51 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Yes, you need to repair it. Get one of those guys who does it because there's always the possibility that it will start spreading. And then you'll have a real mess on your hands.
Old Apr 22, 2007 | 11:04 AM
Seeker135's Avatar
Seeker135
Had the same thing done to my Avalanche. Only visible if you know where to look. Just pay for it yourself as even the "free" glass repair/replacement goes on your insurance record.
Old Apr 22, 2007 | 01:10 PM
Marcmedic's Avatar
Marcmedic
You need to get it fixed before it spreads...just because it's not a crack now doesn't mean it wont turn into one. Shouldn't be more than 50 bucks to have them fill in the chip. I used to repair windshields in college. It'll end up looking like a small bug hit your windshield in the spot after they fixed it. You won't even notice it unless you look really close. Most places will come out to wherever you have the car at and do it.
Old Apr 22, 2007 | 01:42 PM
toolking's Avatar
toolking
Find the local NOVUS repair facility in your area. They have the best methods and generally do the best job.
Old Apr 22, 2007 | 02:34 PM
User 020720
I have a couple little nicks on the windshield, one I got during the first month. None of them are eyesight level, yet. I was driving home last night and heard a pop, I figured it came from the truck in the other lane ahead of me because there were no cars directly in front but found no damage. I try to stay away from cars in front because of this. My hood has a couple nicks as well that needed some touch-up work. I haven't had a car yet that didn't experience this over time. In fact my last F-150 truck got a rock chip that developed into a fullsize crack and also had nicks all over the frontend. Gotta love north Texas construction, makes driving on our freeways a debris filled war zone.
Old Apr 22, 2007 | 02:54 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
Bring it to a good automotive glass place. They work wonders with chips these days.
Old Apr 22, 2007 | 06:12 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Had four big chips show up during the first 3K miles. After sitting in the sun, one chip exploded into a one inch crack. I had it fixed by one of the glass fix guys that my insurance paid for and it came out pretty well (the crack); but had them also try to fix one of the bigger chips which was directly in my line of sight and it didn't turn out so good. It was drilled and filled but it's now more opaque that the rest of the windshield so I still see what looks lihe a small bird crap splat directly in my line of sight. I guess eventually I'll replace the windshield. When the sun is just right, my windshield now looks like I'm looking out during a snowstorm. Never had a vehicle with this many pits/chips at 14K miles.
To do i need a new windshield?
