Dead Battery question
Old Apr 22, 2007 | 11:18 AM
bellagio's Avatar
bellagio
Default Dead Battery question
I have an ipod that i keep plugged in to cig lighter plug. Works on FM transmitter. Seems the new c6 keeps dying out could it be the ipod would that drain battery very quickly if i keep it plugged in with car parked. Any help would be appreciated. Going to jump the dam thing again be back soon
thanks
Old Apr 22, 2007 | 11:20 AM
VET4LES's Avatar
VET4LES
Very good possibility. Don't leave it plugged in and see if you still have the problem.
Old Apr 22, 2007 | 11:22 AM
bellagio's Avatar
bellagio
Default Many thanks
will try that thanks
didnt think something like that could drain so fast but will give it a shot
thanks again
Old Apr 22, 2007 | 11:40 AM
rodfl99's Avatar
rodfl99
Default Dbs
I had DBS 4 times before the dealer found out that it was an open headlamp module that was draining the battery. No IPOD, either. They also replaced the battery because afetr 4 times, it's usually shot.
Old Apr 22, 2007 | 11:56 AM
c6toy's Avatar
c6toy
Default Had same issue!!
I too have an ipod i use with a charging cradle in the cig lighter /and or accessory plug underneath center console.
Power is supplied to these two receptacles Constantly even if the car is off and doors are closed. I found this out the hard way as my radar detector was on when I opened the car door the next morning
It will definately cause your battery to drain in 2 days time easily. Good luck and unplug unplug unplug!!!
Old Apr 22, 2007 | 12:16 PM
johnodrake's Avatar
johnodrake
Moderator
The lighter plug in the ash receiver/coin holder () is switched so it should not be the culprit. The console accessory plug is NOT switched, however and the LED will drain the battery - I know from experience .
Old Apr 22, 2007 | 12:26 PM
calemasters's Avatar
calemasters
thanks
There is a PI on this. You may want to see your dealer. #PIC4188D
Old Apr 22, 2007 | 02:40 PM
Hoonose's Avatar
Hoonose
I would guess that drawing 1 amp/hr or so would be more than these accessories need. They must be preventing the car from shutting down, and causing a 'DBS' like effect.
To Dead Battery question
