DIC Brighter
Old Apr 22, 2007 | 04:20 PM
ROD BROWN's Avatar
ROD BROWN
Default DIC Brighter
How can I make the DIC brighter so I can see it in the daylight?I looked in the owners Manual,but I didn't see any info on it.
Old Apr 22, 2007 | 04:53 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Take off your Sun Cool Glasses
I don't know of a way to do it
Old Apr 22, 2007 | 04:57 PM
overrev64's Avatar
overrev64
I believe you use the same **** that dims or brightens the gauge lights. Turn clockwise and hold to brighten or turn counter-clockwise and hold to dim.
Old Apr 22, 2007 | 06:27 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There is a + and - buttons on the HUD control which do the brightness
Old Apr 22, 2007 | 06:28 PM
ROD BROWN's Avatar
ROD BROWN
Default You are correct
Well,the title says it all. Much thanks.Rod
Old Apr 22, 2007 | 08:28 PM
Vette_DD's Avatar
Vette_DD
No, that only adjusts the brightness of the HUD.
Overrev64 had it right.
2006 owner's manual, page 3-19.
Instrument Panel Brightness
The **** for this feature is
located on the left side of
the instrument panel.
Push the **** in to turn on the interior lights.
Turn and hold the **** clockwise to brighten the lights
or counterclockwise to dim them. During the day,
this **** will adjust the instrument panel brightness and
at night will adjust all interior lighting.
Be sure not to have this **** turned all the way down
with the lamps on during the day. Your Driver
Information Center (DIC) may not be visible
Old Apr 22, 2007 | 08:31 PM
dgrant3830's Avatar
dgrant3830
Sorry, minor DUH Attack...didn't read it carefully enough.
Old Apr 24, 2007 | 03:31 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
To DIC Brighter
