OnStar Electronics
Old Apr 23, 2007 | 10:21 AM
b4i4getit's Avatar
b4i4getit
Default OnStar Electronics
I was looking at a loaded CTS-V the other day and noticed that Cadillac has found a way to mount the OnStar electronics somewhere other than the windshield. Why must we C6 owners have to put up with that ugly little box attached to the upper right of our windshield ?
Old Apr 23, 2007 | 10:54 AM
MNVette's Avatar
MNVette
On the CTS, I believe the antenna for OnStar is on the rear roof near the glass, correct? It looks like a pimple or fin? The 2005 C6 used a similar looking thing for the XM/GPS antenna, but the only place you can put it on the C6 is on the bar between the roof panel and rear glass. Ugly as sin. They found a way to bury the XM antenna in the rear door mirrors, but the GPS/OnStar needs a bigger look at the sky. The box on the glass is about the only place to put it. Where else can it go if you don't want an antenna stuck to the exterior of the car?
Old Apr 23, 2007 | 11:41 AM
jabez's Avatar
jabez
I don't even notice it.
Old Apr 23, 2007 | 11:53 AM
Vette_DD's Avatar
Vette_DD
Smaller surface area for the vette. Fewer places to put it. I never noticed mine the 18 months I had one.
Old Apr 23, 2007 | 02:13 PM
Lightning Coyote's Avatar
Lightning Coyote
I never notice it.
Old Apr 23, 2007 | 02:34 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
Mine's in the same location where I mounted my V1 in my C5 so I had to mount it under the mirror.
Old Apr 23, 2007 | 05:56 PM
Snagle's Avatar
Snagle
Old Apr 23, 2007 | 07:08 PM
PAVette's Avatar
PAVette
Old Apr 23, 2007 | 08:01 PM
rakuhn's Avatar
rakuhn
I have no complaints with it. You really have to be looking pretty darn close to notice it. For me, no big deal.
Old Apr 23, 2007 | 08:31 PM
Tom_Slick's Avatar
Tom_Slick
Old Apr 24, 2007 | 07:36 AM
BlackZ51Vett's Avatar
BlackZ51Vett
What they said....
Old Apr 24, 2007 | 08:03 AM
b4i4getit's Avatar
b4i4getit
Originally Posted by BlackZ51Vett
What they said....
What a tough crowd. The point I was making is that GM can see fit to do a cleaner installation on their cheapest Caddie yet they cannot do the same for their most expensive Chevy. A lot of corners were cut on the C6 and some people refuse to see it.
Old Apr 24, 2007 | 08:36 AM
BriscoCounty's Avatar
BriscoCounty
Well, now I don't have to ask what that box is! Does seem very large, but I didn't notice it until I was halfway home the first day I had my C6. Could of been in a better place, but there isn't anything you can do about it now.
Old Apr 24, 2007 | 08:40 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
how about mounting it in the nose and using the 'emblem' as it's eye-to-the-sky.
Old Apr 24, 2007 | 08:42 AM
havesleep's Avatar
havesleep
I have a 2007 vert and where else would you put it.
Old Apr 24, 2007 | 10:06 AM
MNVette's Avatar
MNVette
This isn't a tough crowd - it is reality. You say that Cadillac "found" a way to make an attractive placement for the OnStar and XM antennas? True enough, but then again they have an entire non-removable roof panel to use as a mounting bracket don't they? Let us review basic science - the C6 comes as both a coupe and vert. That means that unless GM is going to use a completely different set-up for each type of car (thereby costing millions upon millions of dollars), a common approach is necessary. Second, the OnStar, NAV, and XM systems need to be able to "see" the sky in an unobstructed fashion in order to receive the necessary signals. Ok....an antenna was slimmed down for 2006 and put in the door mirrors, thereby getting rid of the "nipple" on the roof bar from 2005. Hmmm....now, where can they put the other antennas? On the roof? No, the roof comes off - that won't work, especially on the vert. On the rear lid? Nope - mostly glass on the coupe. The only place left is the box on the glass. Where else would you put it where it can still work?
Old Apr 24, 2007 | 11:47 AM
b4i4getit's Avatar
b4i4getit
Quit being so defensive about a poor implementation. Unless of course you are the GM engineer who designed this. Also note that any decent packaging engineer could have designed the window wart to be smaller and integrated it within the rear view mirror housing. After all this is what it connects to anyway. Then it would not look like so much as an afterthought as it appears now. This will probably be what they do for 2009 now that I have mentioned it.
To OnStar Electronics
