"Service Steering Lock"????
Old Apr 29, 2007 | 11:45 AM
ttlpakg's Avatar
ttlpakg
Default "Service Steering Lock"????
Got stranded yesterday. Tried to start it - nothing. Had power, but the engine woundnt turn over. DIC read "service steering lock". I dont understand, what does my steering lock have to do with my car starting?? I have a 2005 and it was shut down properly (in reverse and e-brake engaged).
I did a search and saw read that C5's had problems with this. Any C6 owners experience this???
Old Apr 29, 2007 | 01:13 PM
KGB6's Avatar
KGB6
It sounds like the steering column lock needs to be replaced. I have a 2005 also, and mine's went bad at 2200 miles. The car was at the dealer for nearly 2 weeks waiting for the part.
Old Apr 29, 2007 | 01:20 PM
VET4LES's Avatar
VET4LES
When the battery is low you get a lot of messages that don't mean anything. It sounds like you need a new battery. Setting the emergency brake is not necessary in the shut down procedure unless you have memory seat's and steering. Good luck.
Old Apr 29, 2007 | 01:33 PM
Silver Fox's Avatar
Silver Fox
Default Steering Lock
Go to search and type in steering lock. There are so many post on this subject you'll spent 1/2 a day reading them. This is a serious defect get it fixed right away.
Old Apr 29, 2007 | 06:05 PM
ttlpakg's Avatar
ttlpakg
Thanks all. Its at the dealership now for repair. Hopefully it wont take long to fix.
Old May 2, 2007 | 06:13 PM
oyealiz's Avatar
oyealiz
2022 C8 of the Year Finalist - Unmodified
CI 3-4-5-6-7-8-9-10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'16
and mine is sitting home in my garage with the same issue.
Old May 2, 2007 | 06:24 PM
corvette1's Avatar
corvette1
This is a royal PITA, which is why the column lock was removed after the 2005 model year. That doesn't help your situation but it has been addressed by GM(finally) I hope it all works out for you, hang in there.
Old May 2, 2007 | 06:26 PM
oyealiz's Avatar
oyealiz
i suppose it WAS too much to ask that it be removed after..oh...say 98????
Old May 2, 2007 | 07:27 PM
fastskyline's Avatar
fastskyline
i had the same problem. everybody told me it was the battery. after the 3rd tow to the dealer for the same problem they finally replaced the column lock. still have the same battery and havent had the lock problem for 6-7 months now. good luck!
To "Service Steering Lock"????
