Odometer Display
Old Apr 30, 2007 | 01:12 AM
PIZZA LAW's Avatar
PIZZA LAW
Default Odometer Display
Sometimes The Odometer Display Will Stay On The Mileage Reading And Sometimes The Display Will Show The Gear That I Am In When In "sport Mode" And Using The Paddle Shift. I Have Changed It Back To The Odometer Display But As Soon As I Shift The Display Shows The Gear Again. This Does Not Happen All The Time, What Am I Doing To Make It Not Default To The Odometer?
Old Apr 30, 2007 | 01:21 AM
Zymurgy's Avatar
Zymurgy
Moderator
From the owners manual (page 2-29 for 2006):
When you up-shift or
down-shift when using
the Manual Paddle Shift
Feature while in the
SPORT MODE (S),
the current gear will be
displayed in the Driver
Information (DIC), or the
Head-Up Display (HUD), if
the vehicle has this feature.
Old Apr 30, 2007 | 01:27 AM
PIZZA LAW's Avatar
PIZZA LAW
I Have A 2007 A6 With Paddle Shift And A Hud. What Has Me Puzzled Is That The Current Gear Does Not Always Show In The Dic, Just Sometimes. Am I Doing Or Not Doing Something To Make It Default To Display The Gear In The Dic?
Old Apr 30, 2007 | 09:21 AM
Deftly's Avatar
Deftly
Interesting. I have a HUD and the gear only shows there. I have never seen in in the DIC - or it only shows for a short time like the cruise control message and I have missed it.
Old Apr 30, 2007 | 09:30 AM
RadarP3C's Avatar
RadarP3C
I have the HUD. If you're using the paddles and using your nav at the same time the nav will over ride the info in the HUD and your gear selection will be displayed in the DIC. When the nav is finished with the HUD, then gear selection will go back to the HUD display.
Old Apr 30, 2007 | 02:13 PM
Lightning Coyote's Avatar
Lightning Coyote
Mine won't show which gear until I use the paddles.
Old Apr 30, 2007 | 03:52 PM
Zymurgy's Avatar
Zymurgy
Moderator
Yes, Lightning Coyote has your answer:
The gear will not display unless:
1) You have the transmission in the S (Sport) position
2) You actually use the paddles to up-shift or down-shift
If you are in S mode and don't touch the paddles, the gear will not display.
Old Sep 22, 2007 | 01:06 AM
PhotoLad's Avatar
PhotoLad
I think that's it It showed up in the DIC the other day on me after 1 year and I haven't gotten it to repeat since. I will try the Nav.
To Odometer Display
