LS3 hp rating
I have no idea on how the LS2 would (or has) fair based on the new test. I have seen speculation that it would be higher than 400 and speculation that it would be lower than the current 400. Anybody's guess.
Paul
GM hasn't formally released certified numbers for the LS2, so we don't know for sure what they might be. However, at the bash they showed a comparison graph between the LS2 and LS3 (which is tested under the new system) that showed the LS2 at 395 hp. We don't know if that is the result of an actual test under the new system or just an estimate of what it would be under the new system. But it is curious that GM would show the engine making less power than they have previously claimed unless there is some reason to believe it wouldn't test the same in a witnessed test as what they have previously claimed.
i thought that i read a post stating that the LS2 would be rated at 412 under the new method. sounds about right to me. that's one of the reasons that i can't get excited about a 430/436 LS3. not much difference IMHO. (hp that is)
With all the competition using horsepower as a major marketing aspect of cars, I would think any previous tests that differ from current standards with neutral 3rd party observer were probably exaggerated as opposed to conservative estimates. Why would Chevy market the LS2 Corvette at 400 hp, if it was really 412? I doubt this motor has more than 400 hp stock, if it was marketed as such. I'm sure they squeezed it for all it's worth so they could hit 400 hp on a test.
Lifetime Vette Lover
My 07 LMB 3LT is fast... it's real fast stock.
An extra 36 horses, in my opinion, wouldn't be a major difference. I'll keep my 07 until the C7.
Some of my friends and I were presented with a similar dilemma when the 2001 BMW M Coupe was released with 315hp, and our 1999-2000 cars, which were ostensibly identical otherwise, had only 240hp. That was a huge difference, but trading up cost $10K+ Did I? No. If I were taking a hit on the C6 it would likely be for a Z06 or a C7.
The LS2 in the SSR pickup was rated at 395 with automatic and 400 hp with the optional manual transmission. Who knows.
1 Post
St. Jude Donor '13
Even my 05 LS2 GTO felt alot stronger than my 04 Z51.
For those of you whose LS2 based C6s are stock, the difference in horsepower between the LS2 and LS3, no matter the system used to rate either, might be an issue.
But for those with minor to mild modifications, it is not.
[QUOTE=CHASLS2;1560056160]I went from a 04 Z51 a4 to a 06 a6, and i can tell a huge diff in the power! Maybe the gearing in the A6 has something to do with that feeling.
i did the same 04, A4/Z51. my 07, A6 is a COMPLETELY different driving/feeling car. but again thats 50 hp and the gearing.
