Quickest Performance upgrade?
Old May 8, 2007 | 04:04 PM
Irish C6's Avatar
Irish C6
Default Quickest Performance upgrade?
What is the quickest and cheapest performance upgrade that you would all recommend?
It's an A6
thanks
Old May 8, 2007 | 04:06 PM
blackvett's Avatar
blackvett
header's!!!!
Old May 8, 2007 | 04:12 PM
Z06LUST's Avatar
Z06LUST
St. Jude Donor '12
thanks
DRIVING SCHOOL!!!
Blackssr's Avatar
Blackssr
Z06.
Old May 8, 2007 | 04:21 PM
andyandy98's Avatar
andyandy98
A 20 year blonde in a bikini riding shotgun.
Old May 8, 2007 | 04:32 PM
Buffy's Avatar
Buffy
Headers are the quickest and simplest, a cam is probably the most bang for the buck. The cost is fairly similar if you have them installed: the cam is fairly cheap but the installation is expensive, the headers are expensive but installation is cheap or an easy do-it-yourself.
Both will require a tune in order to get all the power gains available, might as well factor that in.
A cam will probably void your warranty on pretty much anything engine-related, headers probably won't. Of course this varys depending on the problem, the dealer, your middle name and the phase of the moon.
Opinions are divided on the gain (if any) from the various intakes. The general consensus is that exhaust mods (other than headers and cats) provide little if any gains.
Old May 8, 2007 | 04:44 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
if the question is most bang for the buck. But if the question really is as stated ("quickest and least expensive") then the answer is premium gas. Only costs a few dollars and takes no longer than a regular fill-up. You MIGHT even be able to tell the difference in performance. That's more than you can say for many of the performance upgrades sold.
Old May 8, 2007 | 04:45 PM
Mr. Scary's Avatar
Mr. Scary
I'l take a brunette too!
Old May 8, 2007 | 05:26 PM
08VelocityZ's Avatar
08VelocityZ
yep.. that'd do it!
Old May 8, 2007 | 05:27 PM
71stang99's Avatar
71stang99
gears. Even though I dont have them I have upgraded prior cars and its a world of difference.
Old May 8, 2007 | 05:33 PM
VET4LES's Avatar
VET4LES
Old May 8, 2007 | 05:36 PM
RED2008Z06's Avatar
RED2008Z06
Originally Posted by Blackssr
Z06.
He said cheapest
Old May 8, 2007 | 05:53 PM
racerrob333's Avatar
racerrob333
if you have the 6 speed auto the new 315 gear will be great and give you better gain than the headers
Old May 8, 2007 | 06:43 PM
Dave Tracy's Avatar
Dave Tracy
Minus the bikinis
Old May 8, 2007 | 07:08 PM
SliverMeMembers's Avatar
SliverMeMembers
SMM
Old May 8, 2007 | 07:16 PM
bocabob's Avatar
bocabob
I have one of those! Not Safe
At times when she is riding with me, I end up flooring it every few miles and weave occasionally.
Old May 8, 2007 | 07:20 PM
Gene Gorman's Avatar
Gene Gorman
After almost $30,000 in mods. and thinking about it. The $150 I spent for the Hurst shifter.
To Quickest Performance upgrade?
Old May 8, 2007 | 07:26 PM
andyandy98's Avatar
andyandy98
Old May 8, 2007 | 07:27 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Predator tune.....cheapest up-grade period.
Old May 8, 2007 | 07:36 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Gears.
