build sheet/window sticker
Old May 13, 2007 | 11:54 AM
rapidrikC6's Avatar
rapidrikC6
Default build sheet/window sticker
I just received the build sheet/window sticker for my 06 C6 from NCM. How do you tell the date the car was built? Can't seem to locate it on either document.
Old May 13, 2007 | 12:00 PM
calemasters's Avatar
calemasters
Someone that has access to GM VIS can input your VIN to find the build date.
Old May 13, 2007 | 12:06 PM
Nassau Blue Hardtop's Avatar
Nassau Blue Hardtop
Default Date of Build
The date your car was built is not on the Window sticker or the Build sheet. The key to that info is the Job Number, which the friendly folks at the Museum can use to call the Factory and find out the actual Build date for that Job Number. Try asking for Gary or Lori in the Guest Services/Delivery department at the Museum. Good Luck.
Old May 13, 2007 | 12:09 PM
2008corvette's Avatar
2008corvette
Send a PM with your VIN # to forum member GMautotech, he will give you your build date along with 3 pages of info on your car.
http://forums.corvetteforum.com/member.php?u=221526
Old May 13, 2007 | 12:47 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As others have indicted the build date is not on the build sheet or the window sticker. You need to have your VIN run through the GM VIS. GMautotech has been doing this for other members. The VIS report will have your build date and all option RPO information on it.
Paul
Old May 13, 2007 | 12:58 PM
71stang99's Avatar
71stang99
As posted above but include your email address. He was very helpful and had it the same day. Mine was built on the eve of Christmas eve.
Old May 13, 2007 | 08:12 PM
Mad*Max's Avatar
Mad*Max
The dealer has the build date on the computer - any work order from them will have the date. The sticker on the driver's door only has the month/year.
Old May 15, 2007 | 12:53 PM
rapidrikC6's Avatar
rapidrikC6
Thanks, guys!!!
Old May 15, 2007 | 02:29 PM
AFVETTE's Avatar
AFVETTE
Nice advatar photo
Tom
Old May 15, 2007 | 07:25 PM
rapidrikC6's Avatar
rapidrikC6
Originally Posted by AFVETTE
Nice advatar photo
Tom
Thanks, Tom
Hoping to go to Road America again this year for thr ALMS race
To build sheet/window sticker
