bummer
Old May 13, 2007 | 11:06 PM
huckleberrydude's Avatar
huckleberrydude
Default bummer
down to three stations in town that carry 93. can't run on anything else. Anyone want to invest in a good gas station? lol
Old May 13, 2007 | 11:15 PM
blkc6z51's Avatar
blkc6z51
Why can't you run on any thing else.
Old May 13, 2007 | 11:18 PM
SpankUU's Avatar
SpankUU
The best I can do in Calif is 91 octane and no other choices that I am aware of and I work in an Oil Refinery making the stuff.
Old May 13, 2007 | 11:33 PM
falco84's Avatar
falco84
Don't you know, it'll stop working.
I drove a C5 on nothing but 87 for 22k miles.
Old May 13, 2007 | 11:35 PM
Maui's Avatar
Maui
St. Jude Donor '08
91 is the max I've seen in Oregon unless you buy racing fuel.
Old May 13, 2007 | 11:36 PM
OregonC6's Avatar
OregonC6
You are experiencing what you may be too young to have experienced in the past.....the demise of leaded premium was the same......near the 'end' I used to plan outings in my gen one big block and Z28 camaros to hit the known leaded premium stations along the route.
Old May 13, 2007 | 11:38 PM
Vette_DD's Avatar
Vette_DD
2006 owner's manual, page 5-5.
If your vehicle has the 6.0L V8 engine (VIN Code U),
use premium unleaded gasoline with a posted octane
rating of 91 or higher.
What are you driving?
Old May 14, 2007 | 12:41 AM
C6Brian's Avatar
C6Brian
All C6 corvettes have two stock tunes. One is for high octane and the other is for low octane. They also have knock sensors that determine if the car is detonating from too low of octane and will pull timing accrodingly. Nothing to worry about using the low octane, you will just be running a tune that has a few degrees less timing and you would never be able to tell the difference. If you had your car custom tuned for 93, then you'd be screwed. Otherwise, your ok. You should really keep a bottle of octane booster in your car too if you should happen on a gas station that doesnt have 93.
To bummer
