Active Handling Advise
Old May 18, 2007 | 12:22 PM
SlickC6's Avatar
SlickC6
Default Active Handling Advise
Service active handling alert comes on frequently. Yesterday while driving about 45 MPH on a straight road active handling kicked in, the car did kind of a compression brake and pulled to one side.
I realize I need to take it in for service, but I don't have time right now.
My question is. I want to take the car on a club outing, poker run etc.. on Memorial Day. Should I just disable the active handling. I will be on dry roads and driving conservatively.
Old May 18, 2007 | 12:24 PM
User 81424's Avatar
User 81424
Yes turn it off!!!!!!!!! You really need to get it to the dealer now, not later. May just be the steering sensor problem.
Old May 18, 2007 | 01:37 PM
SimonStern's Avatar
SimonStern
"Should I drive around in a high performance car on a club event where there will be a lot of OTHER high performance cars who's owner's probably don't want to be smashed into, when my brakes are acting unpredicably?"
Is that what you are asking? Really? Get your car fixed ASAP.
Old May 18, 2007 | 03:00 PM
Tom_Slick's Avatar
Tom_Slick
Had the same problem and was told there was a recall, yet I never got anything in the mail, had it fixed under warranty.
Old May 18, 2007 | 07:42 PM
richhoff's Avatar
richhoff
Yep, it's probably a 10 minute fix. If you have the telescoping steering, they take some tension out of the wiring so it doesn't pull on the connector.
Old May 18, 2007 | 07:43 PM
Vettlldo's Avatar
Vettlldo
Old May 18, 2007 | 10:58 PM
Jimbeaux's Avatar
Jimbeaux
Old May 19, 2007 | 08:13 AM
b4i4getit's Avatar
b4i4getit
Use the search function. Easy fix to do by yourself.
To Active Handling Advise
