HELP Rear Bumper Inserts
Old May 26, 2007 | 03:52 PM
pittguy79's Avatar
pittguy79
Default HELP Rear Bumper Inserts
Got a set of rear bumper inserts. The tape does not cover the entire letter for all of the letters. Is there a "adhesive" that can be used to attach the corners of a few of the letters without damage to the finish? Thanks!
Old May 26, 2007 | 03:56 PM
AFVETTE's Avatar
AFVETTE
I think I'd contact the vendor and ask for a new set. They appear to be defective. I'm sure some one will suggest contact cement etc, but to me if the product doesn't work out of the box as advertised it's defective and I send it back.
I've had my SS Insert letters on for 14 months now and they look marvelous.
Good luck
Tom
Old May 26, 2007 | 07:36 PM
Tom_Slick's Avatar
Tom_Slick
My first set was like that, ended up trashing them. The ones from RPI Design fit much better, better tape coverage!
Old May 26, 2007 | 07:51 PM
Boozman's Avatar
Boozman
Default I had mine painted
pittguy79's Avatar
pittguy79
I just emailed the provider of the letters and asked to return them. Any advice on how to remove them from the car without hurting the surface?
Old May 26, 2007 | 07:53 PM
Tom_Slick's Avatar
Tom_Slick
Some heat from a blow dryer? Then rubbing alcohol to clean up/ remove any glue and prep for next set.
Old May 26, 2007 | 07:57 PM
Tom_Slick's Avatar
Tom_Slick
Originally Posted by Boozman
Yes, but do they sparkle when the sun hits them?
Old May 26, 2007 | 08:16 PM
leftlane1's Avatar
leftlane1
Careful now....we almost get a view of the boys in the reflection.
Old May 26, 2007 | 09:08 PM
SilverStreaker's Avatar
SilverStreaker
All I can saw is what a fine finish. He must have spent 100 hours getting that shine.
I noticed in one of the photos (Feb) he didn't have the inserts in place. Must be a recent addition.
Old May 27, 2007 | 04:49 AM
2LT-Z51's Avatar
2LT-Z51
what is on it now... double stick tape??
Old May 27, 2007 | 10:48 AM
pittguy79's Avatar
pittguy79
Yes it is double stick tape on the inserts
Old May 28, 2007 | 03:22 AM
2LT-Z51's Avatar
2LT-Z51
you should be able to find the tape at the local auto store.... 3M VHB black moulding tape is very common - the clear one will be OK also.....
just let the tape "set" for a 24 hours before a wash....
Old May 28, 2007 | 03:45 AM
07c6vette's Avatar
07c6vette
i had mine for a couple of months and noticed the top part of the letter V started to come out from the tip. when i wipe the car sometimes the cloth gets caught so i decided to remove it. i just pulled it out and used the adhesive cleaner to remove the glue.
there is one more type of inserts that is called "ultra" inserts in chrome finish. i believed it's more flexible too. anyone has tried it? ps share your experience.
Old May 28, 2007 | 03:47 AM
LS WON's Avatar
LS WON
Good luck
Tom
Anyone have pics of this except on an Arctic White Corvette with RED LETTERS?
To HELP Rear Bumper Inserts
