Lowering Help!!!!!!!!!!!!!
Old May 31, 2007 | 08:32 PM
cargeek's Avatar
cargeek
Default Lowering Help!!!!!!!!!!!!!
Hi...I bought Bolt Kit to drop my car... I used them on rear only and it took out Rake, but I think front end went up a whisker... My question is: is there enough adjustment is stock front bolts to drop the front a whisker?
Thanks,
Doug
Old May 31, 2007 | 08:37 PM
carboman's Avatar
carboman
You can get as much as an inch drop out of the stock bolts no problem.
Old May 31, 2007 | 08:43 PM
cargeek's Avatar
cargeek
Thanks........ from all I have heard and read, that is whata I thought..thanks for the confirmation..
Doug
Old May 31, 2007 | 10:28 PM
corvette dave's Avatar
corvette dave
Sorry, not true.
Old May 31, 2007 | 11:10 PM
cargeek's Avatar
cargeek
Default Why not true..what are we missing.????
why not true..very curious..
Doug
Old May 31, 2007 | 11:14 PM
MattStewart85's Avatar
MattStewart85
Doug
I think you can get about 3/4 of an inch maybe that's what he is referring too?
Old May 31, 2007 | 11:20 PM
corvette dave
Doug
Doug,
My 2007 C6 only lowered 2 turns in the rear on the stock bolts. That equaled about 1/4". The front lowered 5 turns, about 5/8".
I had to cut the rear bushings to get the desired look I wanted. (5/8")
I have read many similar posts saying the rear on other cars could only be lowered 2-3 turns on the stock bolts.
All vettes are different but to say that 1" lowering on stock bolts is no problem is just not true. There may be a few to get 1' lower on stock bolts but I haven't seen or heard of one.
I am a little confused about your original post. Did you buy a kit to lower the rear and the FRONT? If so the front should have lowered also.
And the important question: Do you have the stock ride height measurements and the measurements now?
Old May 31, 2007 | 11:25 PM
cargeek's Avatar
cargeek
Default front 3/4"
Ok..all I need out of front is 3/4 inch max with stock.. ..can I get that?
thanks,
Doug
Old May 31, 2007 | 11:28 PM
MattStewart85
i got a half in in the front but didnt turn it all the way i could go lower, but like dave said i think every vette is different..good luck
Old May 31, 2007 | 11:30 PM
corvette dave
thanks,
Doug
You might. I didn't.
Again, all cars are different.
Old May 31, 2007 | 11:41 PM
cargeek's Avatar
cargeek
Default I will try stock..
Hi All.. I will try to get at least 3/4 inch in front with stock bolts.. I will let you know..thanks for all the responses..
Doug
To Lowering Help!!!!!!!!!!!!!
