Valvoline PSF issues
Old Jun 1, 2007 | 07:56 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Default Valvoline PSF issues
I had a gift card to AZ so one of the things I picked up was some Valvoline Synpower power steering fluid. Figured Valvoline was a good name, BITOG recommended it and it stated it met the GM spec for PSF. I hadn't changed the PSF since new and it was VERY dark when I got it out, so I'm thinking, it is a good thing I am changing this fluid.
DON'T do it. The Valvoline Synpower PSF caused intermittent loss of power steering. It was most pronounced from a dead stop. Literally felt like I had lost the power steering pump. It was intermittent and other than from a dead stop, there was no consistency as to when the steering would tighten up or be okay. Actually kind of scary not knowing if you are going to have PS or have to use grunt. Drove to the local chevy dealer and got the GM fluid. Got it home, sucked out the Valvoline and replaced it with the GM stuff and even just in the garage, I could tell problem resolved. I have already done one flush with the GM stuff, will drive it around some then do another replacement.
I will say I am VERY surprised at how quickly the PSF becomes dark, the Valvoline was in only one day and was as dark as the 2 1/2 year old factory fluid. Anyone know why it gets dark so fast?
Old Jun 1, 2007 | 08:15 PM
vetteblack's Avatar
vetteblack
Wow, its a good thing you got it fast. I hope it is not going to cause any long term problems. Sounds like some friction was involved, maybe thats why it got so dark so fast?
Old Jun 1, 2007 | 08:41 PM
ByByBMW's Avatar
ByByBMW
It was almost like the valvoline was to thick for the pump and it wouldn't pump it. Dunno, we'll see if anyone else chimes in.
Old Jun 2, 2007 | 08:41 AM
ByByBMW's Avatar
ByByBMW
ttt
Old Mar 23, 2008 | 06:49 PM
LS WON's Avatar
LS WON
hOW MUCH DOES THE GM STUFF COST?
To Valvoline PSF issues
