hey guys i was checking out the fuid levels in my C6 convertible. I noticed the clutch fluid was pretty low so i went to KRAGEN to get some.
They told me brake fluid was the same as clutch fluid and recommended a BRAKE fluid by Valvoline called SYN power which was fully synthetic. it says on the bottle that it exceeds Dot 3 and Dot 4
Can I add this stuff to the clutch fluid?
I use Prestone DOT 4 Synethic. But any DOT4 will do. To get it real clean, plan on using at least 3 or 4 cans. The Prestone is available from Walmart at about $2.50 a can. Use the Valvoline first, than try the Prestone.
