i currently have an '02 coupe auto with perf axle [3.15 rear gear]
this was important to me back in '02 as the 2.73 standard rear was a bit boring.
i am considering buying a new "07 or '08 auto coupe and notice that the rear gear is 2.53 but it is a 6 speed.
how will this compare to my '02?
and i'm mainly concerned about take-off, not so much the top end.
thanks,
john
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
I had an '00 with 3.15's and I was concerned about the 2.53 gearing on my '07 A6. Because it is an auto 6-speed vs. the auto 4-speed the lower gears are different and the pull in the lower gears on my '07 feels as strong, if not stronger, than on my '00.
You will be happy with the dig on your '07 or '08.
The overall ratio is lower and higher with the 6 speed than with the gears you have in your car. That is the reason the performance ratio was not offered in '06 and '07. It is an option again on the '08.
Gear Ratio times Rear Axle Ratio
__GEAR______Mode__or__Option
____________Z06___Std_6-spd___Z51_6-spd___6-spd_Auto___4-spd_Auto
__1st_______9.10____9.10_______10.16____ ____10.32_____8.35 or 9.64
__2nd_______6.09____6.09________7.08____ _____6.04_____4.45 or 5.13
__3rd_______4.45____4.45________4.89____ _____3.92_____2.73 or 3.15
__4th_______3.42____3.42________3.42____ _____2.94_____1.91 or 2.21
__5th_______2.53____2.53________2.43____ _____2.18
__6th_______1.71____1.71________1.95____ _____1.72
Reverse_____9.92____9.92_______11.22____ _____7.83_____6.25 or 7.21
