Header install question
Old Jun 9, 2007 | 10:09 PM
Mark06's Avatar
Mark06
Default Header install question
How high does the car need to be raised to do the install at home, Will jack stands suffice?
Old Jun 10, 2007 | 12:34 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Did mine on jackstands and ramps.
Old Jun 10, 2007 | 12:40 AM
71stang99's Avatar
71stang99
I was going to do mine in the garage on the floor but to be quite honest I am sick of working on my back. I did have the luxury of using a lift at a hobby shop which made the job way much more easier. Just remember to drill the tunnel plate if you arr going with cats with the wire extensions. Also having a lift makes it easier to line up the tailpipes especially with a catback system.
But to answer your question I have heard 19 or more inches,,,,?
There is at least two webpages devoted to installing headers however they are on a lift.
Old Jun 11, 2007 | 07:26 PM
openhelix's Avatar
openhelix
I did mine with a floor jack and 4 jackstands. easiest header install I've ever done.
Old Jun 11, 2007 | 07:44 PM
timd38's Avatar
timd38
If your 25 it is easy, if your 35, a bit of a challenge, 45, "why am I doing this myself", 55, "how much is installation".......
Old Jun 11, 2007 | 07:47 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
How long does it take to change them out?
Old Jun 11, 2007 | 07:49 PM
openhelix's Avatar
openhelix
Just headers? Half a day, maybe 4-5 hours. Headers and exhaust, a full day.
Old Jun 11, 2007 | 09:55 PM
Mark06's Avatar
Mark06
38, back surgery recipient. But I'm damn tuff & determined
Old Jun 11, 2007 | 11:32 PM
'06 Quicksilver Z06
Woa!!!!! Woa!!!! Woa!!!!!
Back surgery........ No sir!!!!! Get someone to install these for you.
You will be leaning over the car for extended periods, working in somewhat hard to get to areas, crawling underneath the car and making huge demands on you back.
Absolutely not!!!! And don't make me have to tell your wife.
Seriously though, get someone to install these for you. Not worth stirring up your back again and preventing you from enjoying your car after the headers are on it.
But I was serious. I will tell your wife.
Old Jun 12, 2007 | 01:47 AM
longboy4's Avatar
longboy4
.........I put the "Mels" on my car. Jack stands about 14 inchs high. Started at 11:30AM and fired her up just after 7PM. Includes time for breaks and such.
Old Jun 12, 2007 | 06:45 AM
AutoCutter's Avatar
AutoCutter
At 55, I'll still do oil changes, brakes, and engine bay stuff, but crawling under a car in the driveway just doesn't appeal anymore.
Old Jun 12, 2007 | 03:43 PM
vlocty's Avatar
vlocty
Finished mine (LG's) this weekend. Never took the front tires off the Rhino ramps. Had to raise the rear, replaced the mufflers, about 19-20". It was tight, so I would not recommend if you are not fit and flexible.
To Header install question
