Twilight Sentinel Automatic Headlight System - delay question
I am a proud owner of my first Corvette, a silver 2007 C6 (I've posted an intro in the relevant forum).
In this neck of the woods (around Geneva, Switzerland) there are quite a few tunnels and I have noticed that it takes about 15 seconds for the Twilight Sentinel to turn on the headlights, which I think is way too long in case of driving in and out of tunnels every few minutes.
Other than manually turning the headlights on and off, is there a way to shorten the delay?
My dealer says "no, its been a problem ever since the system was introduced" but I'm not sure I believe that.
I think the dealer is right (gasp) in this case. I've not seen anything in the owner's manual or in the discussions here that indicated you could shorten that time.
There is another aspect of the "Twilight Sentinel" that you can modify. That is how long your parking lamps and front fog lamps remain on after you exit the vehicle when it is off or in RAP. That delay can be set to OFF, 15 seconds, 30 seconds, or 90 seconds.
Yes, I ran across that when looking in the manual trying to find an answer to my question. It is set to 15 seconds, and I left it alone.
I've driven in your area and know what you mean with the tunnels. Since there's no way to have the auto headlights come on sooner after you enter a dark area, your best bet is probably to just turn the headlights on manually and leave them on.
The one thing I do like about having the delay is when driving under a wide bridge, it keeps the lights from coming on and then turning off too quickly which is something I notice when BMW's are behind me.
I agree, but still find 15 seconds too long and the fact the owner and/or dealer can't modify this delay is also too bad. I guess it will be "manual" on/off for me then...
My Jag comes on much quicker, and the lights are on by the time I pull into the garage and switch off the engine. With what I've heard about HID lights and repeated cycling (which may not be true, of course), it si best to limit the number of times they turn on for only a brief moment. Of course, there IS a switch.
Try putting a piece of black tape on the sensor, maybe cover 1/2 of it. This might make it think it's darker than it really is and come on sooner. I did that years ago on another car and it worked. The lights came on earlier in the evening which I wanted, I don't know about faster off and on but it's worth a try.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I think there is another aspect of this to consider. Every time the HID low beams "ignite" there is a surge of current. From what I have read about HID's, the more often they are turned on, especially in a short time frame, the more likely they are to burn out sooner. I have no idea what time frame this is but my guess is GM tried to minimize the rapid ignition, then shutting off, ie short cycling of the on/off sequence of these headlamps by building in the delay. Your scenario is one in which turning them on and leaving them on is the best way to go.
Hope this helps.
Probably a good idea. When in a "tunnel" area, in all my previous cars (and the last two had HID Xenon beams, but no auto on-off) I have always turned the lights on and left them on. I'll be doing the same with the Corvette.
Thanks!
