installing a corsa system and i am having a problem removing the passenger side muffler. i have allready removed the h pipe. should i just force it out or what?
You are supposed to remove the sway bar and remove/bend the corner bracket where the exhaust his the underside.Whatch this video & it explains what to do on the left side.....http://www.ecklers.com/product.asp?d...6912&video=yes
Hoffie,
Great Info, I was wondering how hard it would be to replace the stock exhaust and now I see that its not. I wish I had a lift to work off of.
Thanks for the link
awesome video. i have an automatic and it was that damn tab that i need to bend back. came out beautifully. thanks brother. RIck
Hoffie,
Thanks for the link
When i did my route 66's i undid the H pipe and pushed the whole setup foward just enough to clear the back end of my car, took about 40 mins with another guy and myself to remove the stockers and install the 66's.
