vararam
Old Jun 20, 2007 | 05:30 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
Originally Posted by rothchilds
ok so you have a list of those that people buy and like because of ease of install/quality. Now which one beats the vararam in performance, or even actually increases performance. I tried 2 CAI before the vararam, a K/N and a Halltech. Neither could reproduce the gains the vararam gets. So I defer to my original point, find me one that equals or exceeds the benefits, and costs around the same. Trust me, I'm with everyone on here who agrees this thing is complicated to install, and seems to cost a lot of $$ for what it is, but none of the ones you listed above give the performance benefits the vararam does. No one should be buying a CAI for looks, they buy them for performance increases.
None of them offer the potential of leaking around the filter either, except the VR.
Old Jun 20, 2007 | 05:39 PM
rothchilds's Avatar
rothchilds
and all of them offer the potential of oil from the filter getting in and thru the MAF. I can pick apart a filter's design too. If you want to get technical, there is no aftemarket product out there that is fool proof when it comes to performance gains. Go to a dealer's service writer or mechanics and ask about the horror stories from an incorrectly oiled K/N style filter, and then ask about stories about sand in the engine due to a bad filter seal. See which one comes up more often
Old Jun 20, 2007 | 05:55 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
Maybe, but I know how to oil my filter, not sure how to fix sandblasted valves.
Old Jun 20, 2007 | 06:12 PM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
THAT EASY PUT THE FILTER IN RIGHT AND MAKE SURE THAT THE SEAL IS IN PLACE
Old Jun 20, 2007 | 06:15 PM
Silverspeed
BUT WHAT IF THE FOAM SEAL COMES OFF LIKE IT HAS IN OTHER PEOPLE UNITS AND YOU DONT CATCH IT IN TIME?
Old Jun 20, 2007 | 06:20 PM
KarlK's Avatar
KarlK
When I received my VR, I clamped the top housing to the filter housing using their rubber t handles. There was so much pressure on the area of the clamps, it bowed the center of the upper housing creating an air gap. Very visible.
So what has VR done to correct this? provide a thicker weather seal gasket? Changed their clamping mechanism? beefed up the thickness of the upper housing so it wont bow?
Old Jun 20, 2007 | 06:47 PM
dennis50nj's Avatar
dennis50nj
remember how k&n filters give you more horse power faster ets in the 1/4. no filter is fastest. i think you solved the secret why vr is the fastest no filter
Old Jun 20, 2007 | 07:52 PM
ROADKILL2007's Avatar
ROADKILL2007
Default Cai
Which CAI is the easiest and fastest to return to stock, as I wouldn't want to void the warranty?
Old Jun 20, 2007 | 08:16 PM
aTX427
Guest
Posts: n/a
I am surprised to hear everyone having problems with the install. I did mine if under an hour taking my time, never having done the job before. Fit like a charm.
Old Jun 20, 2007 | 08:20 PM
dennis50nj's Avatar
dennis50nj
i have mods and none have voided the warranty depends on the service department if their cool or jerks
Old Jun 20, 2007 | 08:27 PM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
MY NEW HERO
Old Jun 20, 2007 | 09:35 PM
glennhl's Avatar
glennhl
Sorry, neither of those inlets are Cold Air Inlets. Both of those pull from the front of the engine compartment just like the stock inlet. Cold Air Inlets include the Vararam, Hurricane, Xcelerator, Honker, or LPE to name a few.
You can do a cold air mod for the two you listed by doing the free cold air or the Halltech mod. However, a friend of mine did that on his and we compared IAT's. My IAT with a true CAI got to ambient much quicker than his did.
Old Jun 20, 2007 | 09:42 PM
  #33
Silverspeed
Old Jun 20, 2007 | 10:09 PM
  #34
Irv's Avatar
Irv
I already agreed with you about the VR's performance. What do you want, a signed letter of surrender? My point was that it is possible to build CAI or non-CAI intakes at similar prices that have much better quality and don't fall apart under normal use. The VR's design is very innovative and it very clearly has potential for awesome performance gains, but allowing grit to enter the engine is inexcusible, don't you think? Not to put too fine a point on it, if they fixed the build quality I'd buy one.
