Window indexing!!!
Old Jun 23, 2007 | 02:22 PM
jabez's Avatar
jabez
Originally Posted by jsk96z28
Its better now, but it still ever to slightly touches the A piller when opening.
How long have you been with the indexing problem?
Take it to dealer to have it fixed if it still bothers you. Its Should be still under warranty.
Old Jun 23, 2007 | 02:46 PM
BlueC6's Avatar
BlueC6
I have been having the same problem with my '07. Sometimes I have to reindex everytime I roll the windows down. Maybe my method was wrong. I will try the two-3sec holds. See if that fixes it.
Old Jun 23, 2007 | 05:21 PM
rzone's Avatar
rzone
I came home from a week on the road, got in my car last night and the
drivers side window really hit the A pillar too, I re-indexed with the
3 second trick, no joy.
Drove the car around, hit a good bump, heard some sort of pop like the
roof was moving a bit. When I went to get out, I checked the window, still rubbed.
Then I come back from the coffee shop, go to get in, and its not rubbing!
Crazy thing.
I have no idea what was going on there, but something had moved,
or the rubber had compressed allowing the window to go up farther.
Old Jun 23, 2007 | 06:33 PM
Gambok's Avatar
Gambok
Funny my C6 window on the drivers side does'nt go up after you shut the door as of today..maybe me reading this thread jinxed it! You do you reset that?!
Old Jun 23, 2007 | 07:15 PM
Vettlldo's Avatar
Vettlldo
I have had to re-index my windows twice now in 1 year and it's always the passenger side that has the problem. Battery was not disconnected at any point either...but I did stay at a Holiday Inn Express.
Old Jun 23, 2007 | 07:43 PM
2vettes's Avatar
2vettes
Yes, if your window doesn't go all the way after you close the door, you must follow the re-index instructions.
BTW, 28 months, 11k + miles, and no re-indexing req'd except after battery dsconnect.
Old Jun 23, 2007 | 07:51 PM
Les-10's Avatar
Les-10
Bow-Tie Guy
[QUOTE=2vettes;1560799927]Yes, if your window doesn't go all the way after you close the door, you must follow the re-index instructions.
Old Jun 24, 2007 | 02:52 PM
Gambok's Avatar
Gambok
Thanks I did it and now it works correctly..funny I never disconnected the battery or anything.
Old Jun 24, 2007 | 05:36 PM
webdzynes's Avatar
webdzynes
No manual handy - whats the procedure to index them?
Old Jun 24, 2007 | 08:06 PM
Gambok's Avatar
Gambok
Here is what I did..
I ran the car , turned it off and sitting in the car with the door still shut I held the up button for 3+ seconds, then I released and then held again for another 3+ seconds and released and it was done.
In fact when I first held it for 3 seconds it went up a bit and then on the second time it went up a bit more and that was it!
Old Jun 24, 2007 | 09:50 PM
User 020720's Avatar
User 020720
Now you should be able to completely diagnose the problem next time it happens.
Old Jun 24, 2007 | 10:57 PM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
In a year and a half I had to only re-index once due to rubbing.
Old Jun 25, 2007 | 02:20 AM
  #33
jonesaut's Avatar
jonesaut
60,000 + on 05 C6
index one time after battery replacement
