LED tail light kits
Old Jun 23, 2007 | 01:20 PM
holdin5aces's Avatar
holdin5aces
Default LED tail light kits
Read they are really cool and very bright. Too bright? Checked a couple of vendors with no luck. Where did you get yours? Found a 31 led bulb kit on ebay. No housing, just bulbs the seller says are snap in's. The DIY thread in FAQ was an entire assembly.
Old Jun 23, 2007 | 01:35 PM
2LT-Z51's Avatar
2LT-Z51
i don't think anyone is making them yet.... i changed only my bulbs to LED's....
the LED's match the color and brightness of the stock center stop light
there is also no bulb lag... (instant on /off)
here are some old pictures....
the left bulb is the type to use - need to have reflected light
brake on
parking light.... (yes it is that bright - but you can tell the difference when you press the brake)
Old Jun 23, 2007 | 08:08 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Stan, did you install the resistors? or do they still blink too fast?
Old Jun 23, 2007 | 11:09 PM
Vettlldo's Avatar
Vettlldo
(curious about the resistors as well)
Old Jun 23, 2007 | 11:21 PM
stanstiles's Avatar
stanstiles
I did install the resistors, which came with the kit. Without them, the lights blink way too fast and look mickey mouse. I gotta tell you, this kit is just as simple as can be to install. Took less than a half hour for all four.
Had a niuce club drive to a local winery today and had 3 others ask about them. The guy following me on the drive said they were terrific. He has MR C5 and I expect the next time I see it, the lights will be LED.
Old Jun 23, 2007 | 11:28 PM
Vettlldo's Avatar
Vettlldo
What kit? Those bulbs are the same bulbs I used on my C5 w/European taillights. I purchased mine @ www.autolumination.com and I see they have LED flashers now.
Old Jun 23, 2007 | 11:33 PM
2LT-Z51's Avatar
2LT-Z51
yes i did... finally...
before resistors.....
now with resistors...
Old Jun 24, 2007 | 07:43 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Originally Posted by Vettlldo
What kit? Those bulbs are the same bulbs I used on my C6 w/European taillights. I purchased mine @ www.autolumination.com and I see they have LED flashers now.
Old Jun 24, 2007 | 09:06 AM
BaBa Booey's Avatar
BaBa Booey
I may have to look into some LEDs
Old Jun 24, 2007 | 10:30 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Echo Echo Echo
What kit?
Echo Echo Echo
Elmer
Old Aug 3, 2007 | 09:24 PM
rollin18's Avatar
rollin18
what were the specs on the resistors???
i
Old Aug 3, 2007 | 09:58 PM
carboman's Avatar
carboman
brake on
Please post your source and pricing!
Old Aug 3, 2007 | 10:00 PM
rsmithuf's Avatar
rsmithuf
Default You mean these kits?
I tried selling these retrofits but really couldn't get a good price worked out and the issues with DOT approval sorted out to my liking.
Old Aug 3, 2007 | 10:02 PM
rsmithuf's Avatar
rsmithuf
i
You can get load resistors pretty much anywhere. Most places sell 8 ohm ones for approximately $5-10. I have about 40 left over after trying to do the taillight retrofits, I'll sell you some if you're interested. Shoot me a PM if you are.
Old Aug 3, 2007 | 10:09 PM
rsmithuf's Avatar
rsmithuf
You can buy load resistors here:
http://autolumination.com/equalizers.htm
You'll want the 6 ohm versions. MAKE VERY SURE YOU DO NOT ATTACH THEM ANYWHERE CLOSE TO PLASTIC OR EVEN USE SCREWS TO ATTACH TO PLASTIC. They get so hot and even will transfer that heat down metal screws to plastic and eventually melt that too.
Old Aug 4, 2007 | 12:40 AM
2LT-Z51's Avatar
2LT-Z51
(one for each bulb - don't use the 3 ohm ones they may blow the fuses)
above resistors are for the (burned out bulb feature - fast blinking)
bulbs are 3157 Light Tower II 20 Wide Angle Oval LEDS
Old Aug 4, 2007 | 03:34 AM
rollin18's Avatar
rollin18
i bought the ones that look just like the taller ones in this post except
there are 28 "flux" flat wide angle look Goood
To LED tail light kits
