Rusty rotors
Old Jun 25, 2007 | 10:29 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Originally Posted by Top Flight
do you think the same would happen with after market rotors?
It's NORMAL! Bare metal will rust and quite quickly when wet and exposed to the air. It's NORMAL. EVERY brake rotor in the world regardless of make, model, or brand will rust as described in this thread. What should NOT rust is the hat of the rotor and the area NOT rubbed by the brake pads.
As soon as 1 (one) application of the brakes occurs, all rust is cleared off and the surface is shiny again.
Elmer
Old Jun 25, 2007 | 10:34 AM
bradb's Avatar
bradb
St. Jude Donor '06-'07
Originally Posted by StanNH
Isn't Rusty Rotors a country music star?
(free post #1709)
Old Jun 25, 2007 | 10:35 AM
70454's Avatar
70454
Originally Posted by haljensen
Those of us with '05's also have heavy rust on the hub and cooling vanes of the rotors.
......unless GM was kind enough to replace them when they replaced the squeaky Z51 pads.
Old Jun 25, 2007 | 11:26 AM
Buffy's Avatar
Buffy
No, its my wife's nickname for my car.
Old Jun 25, 2007 | 11:56 AM
eboggs_jkvl
Moderator emeritus
I think I saw a junk yard named Rusty Rotors somewhere?
Old Jun 25, 2007 | 01:18 PM
vetdude's Avatar
vetdude
Elmer
Zinc-coated rotors prevent rusting at the hub area (hat) and at the vanes, but, will show a little surface rust after rain or washing until the pads are applied. Then you just get rust dust on the wheels. OEM rotors and non zinc-coated aftermarket rotors will rust in all these places, unless of course you paint the hats and vanes with rust resistant high heat paint that is.
Old Jun 25, 2007 | 01:22 PM
z06Bigbird's Avatar
z06Bigbird
Originally Posted by vetracn98
Can't you supposedly get ones with some kind of zinc or something to minimize the rust??
If you pour or spray a ton of oil on rotors, they will not rust. Side effect is you will need to replace your front end when you run into someone.
DO NOT USE OIL ON ROTORS!!!!!
Old Jun 25, 2007 | 01:25 PM
z06Bigbird's Avatar
z06Bigbird
We can all blame the Indians, Chinese, and other far east and middle east companies that make many of today's rotors.
Deep pits are caused by contaminants in the slag after recycling the metals from older cars.
My car parts stores tell me to buy Canadian rotors when I have totally worn mine out. ???
Old Jun 25, 2007 | 01:39 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Yes he is. Before that he played Bass in Steve Miller's Band
Old Jun 25, 2007 | 08:07 PM
Eritosthenes's Avatar
Eritosthenes
The only way I can think of to avoid rusty rotors is to replace them with rotors made of something that doesn't rust, like carbon fiber or maybe stainless steel or aluminum. Whatever that material may be, it would have to grip like machined steel and absorb (and then radiate) huge amounts of heat without warping, scoring, cracking, or wearing out in a few hundred miles. That pretty much sums up the problems you'd have with carbon fiber brakes.
Old Jun 25, 2007 | 08:13 PM
Modshack's Avatar
Modshack
Huh? Rotors are Iron. Iron rusts when it gets wet. Doesn't matter if they come from Budapest, Canada, or Mexico..
Old Jun 25, 2007 | 11:01 PM
z06Bigbird's Avatar
z06Bigbird
I was referring to pitted rotors. I may have mispoke in my post.
Thanks.
Old Jun 25, 2007 | 11:02 PM
  #33
z06Bigbird's Avatar
z06Bigbird
Someone mentioned stainless. Believe it or not, some stainless will rust. Apparently, there is a ??class A and a ??class B. The lower grade does rust.
Old Jun 25, 2007 | 11:04 PM
  #34
C-INRED's Avatar
C-INRED
St. Jude Donor '06
It really isn't necessary. Just take it out for a short spin after you wash it and no more rust.
Old Jun 26, 2007 | 02:00 AM
  #35
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Titanium rotors don't rust: Red Devil
Old Jun 26, 2007 | 04:29 AM
  #36
gota07's Avatar
gota07
Cruise-In VIII Veteran
Hate to say it, but whoever told you that does not know what they're talking about.
Old Jun 26, 2007 | 08:03 AM
  #37
AFVETTE's Avatar
AFVETTE
All rotors will rust on the "FIRE PATH" where the pad touches the rotor, it the rest of the rotor that shouldn't rust if they were properely treated.
As you can the rotors on my 06 look like crap after 2 days on the track
That's why I'm replacing them with some DBA slotted performance rotors
Tom
Old Jun 26, 2007 | 11:13 AM
  #38
6 speed Sid's Avatar
6 speed Sid
Rust is normal, as said several times. I would not put anything on the rotors. You can take the rust off with sandpaper or such and clean with brake cleaner, if you want them in show condition, but no oil.
I also have seen some surface rust on what was supposed to be stainless, maybe it was a low grade or something.
