Car throwing P0641 code - interpretation ??
Old Jun 25, 2007 | 12:44 PM
ourayzman's Avatar
ourayzman
Default Car throwing P0641 code - interpretation ??
My car went into reduced engine power mode recently so I pulled codes and it had one, P0641. My code reader interpretted it as
"Sensor A reference Voltage Circuit/Open". Another list of codes indicates it means "5-Volt Reference 1 Circuit ECM". Does anyone know which sensor A is? or have any further information on this code.
Thanks in advance
Old Jun 25, 2007 | 06:45 PM
GMautotech's Avatar
GMautotech
That code is "5-Volt Reference 1 Circuit". That 5v circuit feeds the MAP, fuel tank press, AC press, APP2, oil press and cam sensors. If you don't have a wiring issue, then you probably have one of those sensors going bad and causing incorrect signals on that circuit.
Old Jun 25, 2007 | 08:04 PM
99ssconv's Avatar
99ssconv
If a reduced power message, SES light on, and a erratic oil pressure gauge reading has been duplicated and DTC P0641 is set, inspect the wiring harness behind the left cylinder head.
It is possible that circuit number 2705 (grey wire) which is the five volt reference circuit for the engine oil pressure switch to be chafed to the back of the left cylinder head.
Old Jun 4, 2013 | 06:00 AM
vettedawg2's Avatar
vettedawg2
This is exactly what is happening on mine. I will check the wiring today. Did you get it fixed? What was your issues?
To Car throwing P0641 code - interpretation ??
