Squeaky Roof
Old Jun 25, 2007 | 07:09 PM
bullets1's Avatar
bullets1
Default Squeaky Roof
About a week or so ago there was a post about squeaks in the roof. I though it was coincedental since I had my roof off for several days and noticed squeaks when I put it back on. Responses to that post suggested that dirt on the weatherstripping was the cause with suggestions to clean it off and apply a silicone grease. I planned to do that when I got a round to it. Well, today, the squeak was worse and I noticed while driving it got louder when I applied light pressure to the rear of the panel. Here it comes: My roof is separating!. I had the glue injection fix done last March.
I also noticed a drop of liquid near the front edge of the panel. It smelled chemical and had a slightly greasy quality to it. Don't know if there is a relationship. Didn't see any separation along the front.
Old Jun 25, 2007 | 08:01 PM
99ssconv's Avatar
99ssconv
Creak or Popping Noise from Roof Near Windshield/A Pillar (Replace Plastic Guides in Roof Striker and Add Flocking Tape and Shim Stock) #05-08-59-003E - (05/09/2007)
Models: 2005-2007 Chevrolet Corvette
with Lift Off Roof Only
Condition 1
Some customers may comment on a creak or popping noise in the roof near the windshield area.
Condition 2
Some customers may comment on a creak or popping noise in the A-pillar area.
Cause 1
The roof guide pins may have elongated the plastic guides.
Cause 2
The windshield garnish molding may be causing the noise.
Replace the left and right plastic guide in the roof latch striker following the procedure below. (Note that the latch is on the headliner, next to the "A" pillar.)
Unlatch and remove the roof.
With a small screw driver, unlock the four fingers of the guide from the striker and discard them.
Remove the flocking tape from the new guides.
Install a piece of flocking tape under the brim of each of the guides (8 mm [0.31 in] wide by 50 mm [2 in] long) as shown above.
Install the new plastic guides into the striker.
Install the roof.
Correction 2
Install flocking tape and shim stock to the following areas
• The A-pillar (shim stock)
• At the end of the windshield garnish molding (flocking tape)
Remove the windshield garnish. Refer to Windshield Garnish Molding Replacement in SI.
Install a piece of 2 mm (.080 in) shim stock, 40 mm long by 10 mm wide (0.31 in by 1.6 in) to the A-pillar as shown above.
Install a piece of flocking tape 8 mm wide by 40 mm long (0.31 in by 1.6 in) to the edge of the windshield garnish molding and wrap it around the back side of the molding as shown above.
Install the windshield garnish. Refer to Windshield Garnish Molding Replacement in SI.
Parts Information
Order BRS Tape and Adhesive Back Shim Stock from Kent Automotive at 1-888-YES-KENT or online at www.kent-automotive.com.
Part Number
Description
Qty
19120702
Spacer, RF Lift Off Pnl/Wdo Frt Stkr (LH)
1
19121172
Spacer, RF Lift Off Pnl/Wdo Frt Stkr (RH)
1
KT-13485
BRS Tape
P40100
Old Jun 26, 2007 | 09:59 AM
bullets1's Avatar
bullets1
Thanks for the detailed response. However, there is another cause for squeaks/pops. In my case it's delamination.
To Squeaky Roof
