Decoding a build sheet?
Old Jul 9, 2007 | 02:32 PM
silver-surfer's Avatar
silver-surfer
Default Decoding a build sheet?
Where on the build sheet is the born on date?
Old Jul 9, 2007 | 02:42 PM
Fastronaut's Avatar
Fastronaut
CF Senior Member Emeritus
Just checked my build sheet and there is no date that I can see on it.
mpuzach's Avatar
mpuzach
It's not on the build sheet.
Old Jul 9, 2007 | 02:49 PM
Les-10's Avatar
Les-10
Bow-Tie Guy
You need to get a VIN search for that
Old Jul 9, 2007 | 02:53 PM
MNVette's Avatar
MNVette
It isn't printed anywhere on the build sheet. Call the NCM and ask them to look it up for you, or someone on here can look it up. You'll need your VIN
Old Jul 9, 2007 | 02:54 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The born on date can not be found on the build sheet. The GM VIS has the born on date in the database. A GM dealer or someone with access to the system can run your VIN and provide the date to you.
Old Jul 9, 2007 | 04:02 PM
silver-surfer
Thanks all. I will give my dealer a call.
Old Jul 9, 2007 | 08:00 PM
GMautotech's Avatar
GMautotech
Check my sig
Old Jul 9, 2007 | 09:34 PM
z51vett's Avatar
z51vett
check door jam driver side
Old Jul 9, 2007 | 10:39 PM
geewez's Avatar
geewez
Default How to find the build sheet
I have the window sticker but where can I find the build sheet?
Old Jul 10, 2007 | 06:46 AM
silver-surfer
You can order them from the NCM. $30 I think?
http://www.corvettemuseum.com/
Old Jul 10, 2007 | 06:47 AM
talon90's Avatar
talon90
NCM Ambassador
Nope, only month and year there....not day.
To Decoding a build sheet?
