I was trying to adjust my HUD to go a little higher on the windshield and when i did....it went to opposite way..pushing up made it go down and down made it go up..
but once it got fully to the bottom it got stuck and i can't see it at all unless i put my head next to the roof and look at it!!
Any ideas on how to fix or what happened? Do i just need to go to a dealer?
To sum up what the service manual says, you test to see if the switchs are working correctly and depending of the outcome of the test, replace either the switch pod or the HUD unit.
Your best bet would be to let your service department check it out.
Also, I put in vararam last night and disconnected the battery but i didn't even think to pay attention to the HUD cause i was entertained trying to make sure the car ran fine this morning! ill take a look at this later and see if it is fixed!!
