'05 Radiator Replacement?
Old Jul 19, 2007 | 08:43 AM
mbovino's Avatar
mbovino
Default '05 Radiator Replacement?
I am considering buying a used '05 with around 10,000 miles. The car looks in great shape but in checking the service/warranty history I learned that the radiator was replaced at 1700 miles. Is radiator failure a common problem with the C6? I know that is is with my BMW 7 series (plastic side tanks). Thanks
Old Jul 19, 2007 | 09:16 AM
ufso's Avatar
ufso
They might have damaged the radiator frame which protrudes below and in front of the bottom 3 piece plastic valance. This might have necessitated a new radiator?
Old Jul 19, 2007 | 09:18 AM
not08crmanymore's Avatar
not08crmanymore
never heard of this outside of an accident,but anything is possible.I didn't know the radiator goes lower than the air dam?? That can't be good!
Old Jul 19, 2007 | 09:22 AM
Lee6's Avatar
Lee6
never heard of this being a problem.....
Old Jul 19, 2007 | 09:32 AM
ufso's Avatar
ufso
Yes, those 2 curved black metal brackets under the front end is the radiator frame.
Old Jul 19, 2007 | 09:36 AM
MNVette's Avatar
MNVette
There is no inherent problem with the radiator - sounds like the previous owner ran up onto a curb or something and damaged the radiator, thereby causing the replacement. The radiator really does sit that low. Shouldn't really be an issue. I assume that there is no other real "damage" to the car? It wasn't in a head-on collision or something? If not, then it should be fine.
Old Jul 19, 2007 | 09:38 AM
not08crmanymore
Damn,is that what rubs on the ground sometimes??I always thought it was the air damn.
Old Jul 19, 2007 | 09:59 AM
ufso's Avatar
ufso
Yes, sometimes they do.
DO NOT ATTACH ANY TYPE OF ROLLERS TO THESE.
You could on the C-5, but not the C-6!
Old Jul 19, 2007 | 10:27 AM
Les-10's Avatar
Les-10
Bow-Tie Guy
Old Jul 19, 2007 | 10:29 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
We've seen a few C5/6's come through that have lost rad. due to gators or armadillos down here in FL
To '05 Radiator Replacement?
