2008 Automatic
Old Jul 19, 2007 | 04:55 PM
b4i4getit's Avatar
b4i4getit
Default 2008 Automatic
I read that the 2008 C6 with the auto and 2.73 performance axle ratio will outperform the manual on a 0-60 launch. Can anybody verify this ?
Old Jul 19, 2007 | 04:58 PM
VishnuNath's Avatar
VishnuNath
According to those slides Conti had the auto will do 0-60 in 4.3 while manual was 4.0.. According the the dyno numbers in other threads the manual was actually putting more HP at the wheels, this would confirm those numbers that the manual was indeed faster.
Old Jul 19, 2007 | 06:14 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Not from what I was told. The auto is heavier and while no one will be able to shift faster than the automatic the driveline loss is more significant in the auto on two otherwise equal cars.
Old Jul 19, 2007 | 06:19 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Is there such a thing as a 2.73 performance axle ratio?
Old Jul 19, 2007 | 06:21 PM
talon90's Avatar
talon90
NCM Ambassador
There is for 2008 models.
Old Jul 19, 2007 | 06:24 PM
ExRedRacer's Avatar
ExRedRacer
Then what is the 'standard' axle ratio?
Old Jul 19, 2007 | 06:25 PM
Cjunkie's Avatar
Cjunkie
lol i agree 2.73's being performance gears, hell when i was younger in our 5.0 mustangs those were the FIRST things we tossed for 3.73's or 4.10's.
Old Jul 19, 2007 | 06:28 PM
talon90's Avatar
talon90
NCM Ambassador
2005 A4 = 2.73
A6 = 2.56
M6 = 3.42
A little different from the C5 days with the 2.73 being standard and the performance axle being a 3.15.
Old Jul 19, 2007 | 06:35 PM
orca1946's Avatar
orca1946
In either case , have fun
Old Jul 19, 2007 | 07:28 PM
PAVette's Avatar
PAVette
I've read various things about the new A6...is it a new, but similar, design, or is it just a regeared and chipped version of the current A6 that produces better performance? If its the latter, is there going to be an "upgrade" kit?
Old Jul 19, 2007 | 11:59 PM
Purdue's Avatar
Purdue
The 2.56 is a strong gear ratio in the A6 C6 and the 2.73's will be even stronger! You are looking at the final ratio when you should be looking at the ratio for each gear (not the overdrive gears).
Old Jul 20, 2007 | 06:38 AM
Sportsdude's Avatar
Sportsdude
Anyone know the top speed for the 2.73?
Old Jul 20, 2007 | 07:00 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
FAst !
Old Jul 20, 2007 | 07:06 AM
hawkeyefan's Avatar
hawkeyefan
I have read the same thing also. The only difference is that the A6 had paddle shifters and they were using this information to support the new shift points in the new 2008 transmission.
To 2008 Automatic
