Fuel Performance
Old Jul 21, 2007 | 12:31 PM
pjdisci's Avatar
pjdisci
I put 87 in my new '07 when it first came in. I experienced loud spark knock and at 1600 miles I changed to 93 and it made a big difference. I the manual chevrolet recommnds 91 octane or higher....It's worth the few extra bucks to use the good stuff. I used 93 in my last four vettes, i guess I thought because it was a new car that I could test 87.. i know i state the obvious, but i had to add my 2 cents.....
Old Jul 21, 2007 | 12:35 PM
C8-Vette's Avatar
C8-Vette
Originally Posted by GotVett?
Been seeing the Shell ads lately about it keeping the gunk level down in the engine. Just made me start wondering "fact or fiction".
Shell is one of the few top tier gasolines recommended by GM and
Toyota. High detergent.
Old Jul 21, 2007 | 12:45 PM
GotVett?'s Avatar
GotVett?
I'll give it a try and see if I can tell a difference, even at the higher price.
Old Jul 21, 2007 | 12:52 PM
stingray01's Avatar
stingray01
Here in the U.K. the cheapo gas is 95 ron. thats the very least octane rating we have.thats what I run my c6 on and it's great. difficult to imagine that the vettes can run on 87ron. No wonder they were pinging, not good for the engine. Can't you buy petrol additives to put in the 87 ron if thats the only stuff you can get.
Old Jul 21, 2007 | 02:03 PM
JoesC5's Avatar
JoesC5
Originally Posted by 1500cc
Our city is like that too, with one big fuel terminal that all the stations get their fuel from.
My question is about ethanol. The Sunoco stations here all say on their pumps that the fuel contains at least 10% ethanol. The Petro Canada stations don't say anything about ethanol. I try to avoid using fuels containing ethanol whenever possible, so is it possible that Petro Can doesn't have ethanol even if they're getting their fuel from the same tank farm? Or could Sunoco be adding their ethanol from a different tank and blending it there?
Ethanol is added at the local level. Ethanol can't be shipped via pipeline, only by truck or rail tanker. That's the reason the ethanol plants are being built all over the country, they have to be close to the point of use.
Old Jul 21, 2007 | 05:28 PM
C8-Vette's Avatar
C8-Vette
Get a Shell credit card. Your monthly bill will be reduced by 5 percent.
Old Jul 21, 2007 | 07:10 PM
john351's Avatar
john351
Originally Posted by Wayne O
Maybe that's why Arizona consistently has some of the lowest fuel prices in the nation? But seriously.....
As a practical matter it is virtually impossible to find 93 octane rated fuel in Arizona. My car is tuned specifically for 91 rated octane and I've never had any problem with the "crap" gas in Arizona...my C6 never pings....it 'zings. '
I will use Exxon or Mobil but I try to stay with "top tier" stations. I don't recall seeing any locally but I will never use Citgo gas for political reasons.
Amen on the Citgo for political reasons, no need to shuffle $ to people who'd like to see us dead! I will never buy any Citgo products.
For some reason, I've had bad luck with Shell products - ping, ping, ping!
Chevron, Mobil, Texaco, and Union76 seem to work very well.
Old Jul 21, 2007 | 08:29 PM
jcurley290's Avatar
jcurley290
For 2-3 dollars a tank full stick with the best, because your driving the best.
Old Jul 21, 2007 | 08:34 PM
Mad*Max's Avatar
Mad*Max
I'm really confused about this Ethanol thing - Sunoco Ultra 94 contains up to 10%, should I be using Shell instead? Does it have no Ethanol?
Old Jul 21, 2007 | 09:22 PM
FireLikeIYA's Avatar
FireLikeIYA
http://www.toptiergas.com/
I would only put top tier gas in your vehicle. I prefer Chevron only because all levels of their gas is proven to reduce buildup. Shell only claims their 91 (or 93 if you live back east) will do so. I also prefer QT gas because they are a top tier gas, their stations are very clean, have restrooms, $.99 cent big gulps, etc. etc. etc.
Who cares if all gases comes from the same spigot. The additives are what really matters.
I would stick to higher octane in the summer.
Old Jul 22, 2007 | 05:48 AM
C8-Vette's Avatar
C8-Vette
In NY, and I'm sure in most other states ,they all contain at least 10 percent ethanol. Shell for sure in NY.
Old Jul 22, 2007 | 06:01 AM
stingray01's Avatar
stingray01
Just a thought from across the pond. With your gas being so low in octane how can you run say an impreza, skyline, evo's, ferrari etc. etc. The ecu will adjust I know but at 92-93 octane it's well below M S's and you could get problems. Here we use 'premium' at 98 ron which I put in my gtr r3 so Just wondered how you get round it.
Old Jul 22, 2007 | 06:19 AM
  #33
DREAMERAK's Avatar
DREAMERAK
St. Jude Donor '12-'13-'14, '16
EU 98 is equivelent to US 93 we use a different formula for calculating octane
Old Jul 22, 2007 | 06:37 AM
  #34
Larry B.'s Avatar
Larry B.
Yes... We use RON + Motor Octane divided by 2. So one blend of 93 could be 96/90 while another is 90/96. That's why all 93 is not the same over here. European gas is consistent because of that fact.
Old Jul 22, 2007 | 06:40 AM
  #35
shopdog's Avatar
shopdog
Our octane rating system is different from yours. The reported pump octane is the sum of the research and motor methods divided by 2. The two methods measure slightly different properties that become apparent under different engine operating conditions. Since the motor rating is always lower than the research method rating, our numbers will be lower for equivalent gas than yours.
Our 93 is roughly equivalent to 98 RON, 91 is roughly equivalent to 95 RON. These are only approximations and will vary with varying motor and research numbers (all 93 isn't the same RON or motor, some may have a higher motor and a lower RON, or vice versa depending on the exact formulation coming out of the pipeline that day). The ratio of RON to motor also changes seasonally as gas is formulated to be more or less volatile.
Old Jul 22, 2007 | 06:49 AM
  #36
stingray01's Avatar
stingray01
Dreamrak/larry. That is one compicated business with your gas. Just don't understand why the powers to be in the states don't sort it out so when you buy your gas you know what you are buying, whether it be 87 all the way through to say 95 ron. Looks like by a lot of postings that you have to go to a certain gas station to hopefully get the stuff you want. Seems like a lottery for quality over there.
Old Jul 22, 2007 | 10:16 AM
  #37
Whiterock1's Avatar
Whiterock1
Right on. Euro gas is no different in true octane than US gas. RON is only half of our formula calculation.
To Fuel Performance
Old Oct 9, 2007 | 03:26 PM
  #38
vdavenp802's Avatar
vdavenp802
Originally Posted by bolivar
Do you have any idea of how gasoline is sold?
Traded, exchanged, swapped, bought?
Basically, think about it. Does every brand you see driving down the street have a separate supply available in every area where they have a station?
NO!
Almost all gasoline in a certain area will come from one or two suppliers. Whoever has the nearest pipeline and terminal on that pipeline. A pipeline can carry multiple companies product, but in most cases, a certain location cannot economically support more than one or two wholesale terminals and their distribution network.
All gasoline coming down that pipeline is the same. Coming probably from one refinery. If not, it is all still either just 'regular' or 'premium'.
When the gasoline is loaded into a tanker for delivery at stations, an 'additive package' defined by the brand of station it it going to is added to the gasoline.
And, most additives are about the same. There are octane boosters, detergents, and vapor pressure modifiers mainly. 'Common' chemicals in the gasoline business. But the government has added a mess of regulations in the last 10 years or so, and there are all kinds of stuff that have to be put into it to meet some 'local' regulations. (You people in California have most of this. But large metro cities have also passed laws that pertain to gas sold inside their city/county/etc limits.) All of these are about the same.
Federal law sets specifications the detergents have to meet, and this law has been in place for about 20 year. Just after fuel injected motors came into common use, and some of the detergents in use were not good enough to keep injectors clean, and caused problems. After the Fed specifications, any gasoline should have enough detergent that its use should not cause injector clogs.
Now, there can be water in tanks and if the owner of a set of stations wants to be cheap, he can scrimp on the additives.
But overall, most gasolines are about the same.
And talking about water in the gas. A single pipeline will carry all kinds of different product down the line. Regular, premium, diesel, fuel oil, aviation gasoline, etc, etc. And how are these separated? By a big 'slug' of WATER! So, if the water is not separated out well in pulling the product from the line and pumping it into the specific holding tanks, you could have a lot of water in the gas right from the wholesaler's terminal and loaded into the tankers.
I just have to giggle when I read all the posts about 'I always buy XBrandO gas! Alway have and always will!' You may have NEVER gotten gasoline out of a XBrandO refinery!
(And, in the 'old days' of leaded gas, there was only one kind of gas coming down the pipeline, regular. Premium was obtained by just increasing the lead and butane content, both octane boosters. Without lead, there now is truly regular and premium coming out of the refinery, because the available octane boosters cannot alone reach premium level.)
This is exactly right ON. The extra cost is for profits and advertising.The other issue to enter the picture is when tankers change from diesel/fuel oil to gasoline and do not empty the tank completely.
Old Oct 9, 2007 | 03:49 PM
  #39
Modshack's Avatar
Modshack
BTW, "Top Tier" is marketing hype. A friend of mine busted this myth years ago by showing that the "Quick Trip" brand (conicidentally at the top of the list). had the exact same business address and legal contact as the mythically independent "Top Tier". I'll try to find the screen shots.
http://www.toptiergas.com/retailers.html
Old Oct 9, 2007 | 03:59 PM
  #40
OregonC6's Avatar
OregonC6
no 93 here or withing a thousand miles probably. E85 holds some promise for higher octane fuel ....it is much higher and hp is higher too BUT mileage is lower I have heard.
we have 92 tops here with plenty of water added usually it seems. Eventually the 92 will go away and perhaps all we will have only 87 in the future. I understand that you get less gas from each barrel of oil the higher the octane you produce.
GM sells the Z06 with the recommendation that only 93 octane be used I believe. But this octane is unavailable on the entire west coast so far as I know and lots of other places as well. just a matter of time IMO before our present "high" octane pure gas goes away for good.
bring on the alcohol I guess except that current c6s cannot run on E85.
All these thoughts bring back memories of the demise of leaded premium and what it did to performace cars. The old muscle cars are very valuable now but it beats me what people put in them if they actually want to drive them like when they were new.
