In one section it mentions
"There is still no guzzler tax, the car runs on regular fuel, and emissions are even improved-by 40 percent in NOx and 12 percent in hydrocarbons. The LS3 is even more efficient to manufacture. It's a true win-win-win situation."
Can this be said to mean the 2008/LS3 runs on 87 octane no problem? Or are we still to think that 91/93 is recommended?
I saw that too... However, nothing but 93 will go in my tank lol
The car runs on regular fossil fuel as opposed to E85 (ethanol blend). The performance tables for the Corvette will still be optimized for 91 or better octane gasoline. You can run the current LS2 C6's on 87 as well but as the manual stipulates it will affect acceleration and performance.
2007 owner's manual, page 320, for the LS2 engine.
Gasoline Octane
If your vehicle has the 6.0L V8 engine (VIN
Code U), use premium unleaded gasoline with a
posted octane rating of 91 or higher. You may also
use regular unleaded gasoline rated at 87 octane
or higher, but your vehicle’s acceleration may
be slightly reduced, and you may notice a slight
audible knocking noise, commonly referred to
as spark knock.
I suspect the 2008 owner's manual will read the same for the LS3 engine.
I certainly do not like paying the high gas prices. As I see it, having a Vettem, is rather like having a child, you have to feed it the correct stuff.
It's true, one can choose the lower octane fuels if desired.
Not that it matters much but the LS3 does have a lower compression ratio (typically speaking, a higher CR requires higher octane) than the LS2 (10.7:1 versus 10.9:1 for the LS2) but again that likely isn't much of a factor in this case.
