Busted windsheild
Old Jul 27, 2007 | 04:18 PM
Randy in Atlanta's Avatar
Randy in Atlanta
Default Busted windsheild
I got hit by a rock with only 2200 miles on my 07 Z51
And now I have a crack runing towards the passanger post.
The question, does anybody know the RIGHT way to take the old
windsheild out and get the new one in without tearing the s***
out of the car????
Busted in Atlanta
Randy
Old Jul 27, 2007 | 04:38 PM
Vetteinplano's Avatar
Vetteinplano
Are you planning on doing this yourself?
Call your insurance company and let them refer you to someone.
Old Jul 27, 2007 | 04:41 PM
TMRoc's Avatar
TMRoc
out of the car????
Busted in Atlanta
Randy[/QUOTE]
Randy
Sorry to hear that. But I know what you are going thru, because I just got my vette back from getting the windshield replaced...
I don't know how to that but, It was costly $1468.. Good luck... Luckly my ins. cover all but $200.
Old Jul 27, 2007 | 04:47 PM
AndysZ's Avatar
AndysZ
St. Jude Donor '09
I just had mine done, and it took three trips before they got a good one. The first one didn't have the trim strip glued from the factory, the second one had a haze (between the two layers?) that wouldn't clean up. The third one has the GM logo on it and is perfect !! Make sure you get the GM one first.
Regards, Andy
Old Jul 27, 2007 | 04:53 PM
mforman42's Avatar
mforman42
I've done some windshield replacements before on cars that had much simpler arrangements. A professional is the only way to go. There is way too much that can go wrong. At least if you have a professional do it, especially one recommended by your insurance company, you have some recourse if it doesn't go smoothly. No way I'd do it on my C6.
Old Jul 27, 2007 | 05:14 PM
Randy in Atlanta
Hey, I will standing right there, but one guy said they will
saw the windsheild out. I will only use a professional and
ONLY OEM Glass.
I am looking for info on the proper procedure.
Still busted and heart broken in Atlanta
Randy
Old Jul 27, 2007 | 05:28 PM
MNVette's Avatar
MNVette
Default What?!?
A glass professional said that they would "saw" the glass out of the car? There is NO way that is an approved procedure or in any way, shape, or form correct. The weather stripping is removed, they put tools into the gap, work the glass loose from the adhesive, attach something to the glass so they can lift it, and off it comes. It is not terribly complicated work. Once the glass is off, they clean the frame, reapply proper adhesive and stripping, and install the new glass.
Get a professional to do it, but certainly not the guy who said he'd "saw" the glass out. What kind of an idiot would do that?
Old Jul 27, 2007 | 05:49 PM
Atomic Orange's Avatar
Atomic Orange
Don't forget, if you have HUD you need to get the appropriate windshield for the HUD to work correctly. I just know you hate that that happened. I also suggest you go to a Chevrolet dealership's body shop and ask them who they get to do their work.
Old Jul 27, 2007 | 07:00 PM
z51vett's Avatar
z51vett
WHEN THEY SAY SAW I HOPE THE MEAN TWO STICKS AND PIANO WIRE. DON'T KNOW ABOUT NEW FANGLED SAW IDEA BUT THE OLD WAY WAY WHAT I JUST TOLD YOU ABOUT.
z51vett
Old Jul 27, 2007 | 07:04 PM
ProgGod's Avatar
ProgGod
out of the car????
Busted in Atlanta
Randy
Randy
I don't know how to that but, It was costly $1468.. Good luck... Luckly my ins. cover all but $200.[/QUOTE]
Windshields are the biggest scam. The same company that charges your insurance $1500 for the windshield, will do it for you for $500 cash.
Old Jul 27, 2007 | 08:19 PM
shopdog's Avatar
shopdog
z51vett
Yep, they cut the adhesive bond with the wire saw. They don't try to pry it loose because that adhesive is very strong.
Old Jul 27, 2007 | 08:21 PM
shopdog's Avatar
shopdog
ONLY OEM Glass.
Randy
Just call Safelite. They'll come out to your home or office and do it right there. I've had them change several windshields, and they have repaired the windshield in my Corvette. Nice job, no hassles.
Old Jul 27, 2007 | 08:28 PM
Firedog's Avatar
Firedog
Safelite replaced my windshield 2 years ago, and it looks PERFECT...Great job, and they did the work in my garage...Highly recommended...
Old Jul 27, 2007 | 08:35 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
If you get the OEM windshield you'll be much happier with the results.
Tom
Old Jul 27, 2007 | 09:02 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
For at least the past 30 years the way to remove a windshield is to saw it out with a thin wire between 2 handles. You're sawing the adhesive, not the glass. It's a job for a professional. Any major company will be about the same. Let your insurance company pick one. They've done this before and they will pay the bills until it's right.
Old Jul 27, 2007 | 09:08 PM
NeedaC6's Avatar
NeedaC6
Just had my windshield replaced by Glass Doctors with OEM GM glass and it's perfect.
Used Safelite for my Camaro some time back and I was very aggravated with them, 2 different replacement windshields and it still didn't look like factory.
To Busted windsheild
