production codes
Allocation group VET
Current event 3000
charge to 111452
ship to 113150
tpw 08/20/2007
model 1yy07
order type SRE
Priority 1
order #MDRRNM
Does the model number 1YY07 mean they are trying to give me an 07 when I ordered an 08?
Thanks in advance
Three models:
1YY07 Corvette Coupe
1YY67 Corvette Convertible
1YY87 Corvette Z06 Coupe
YY07 DOES NOT refer to the model year.
Current event 3000 Status Code
charge to 111452 Dealer ID paying for Vette
ship to 113150 Dealer ID delivering your Vette
tpw 08/20/2007 Target Production Week for your build
model 1yy07 Body Style
order type SRE Sold order
Priority 1
order #MDRRNM Order number
Thanks in advance
I see you've got most of your answer. I'll just add the list of event status codes so that you can follow your order in the process.STATUS EVENT CODES
1100-Order placed at dealer
1101-Order accepted by GM
2001-Order generated to dealer
2005-Order replaced with GM Prospec order
2050-Order changed
2500-Order sent to production, preferenced
3000-Order accepted by production control
3100-Order available to sequence (now the tpw becomes more stable)
3300-Order selected for production by assembly plant
3400-Order broadcasted for production
3800-Vehicle produced
4150-Vehicle invoiced to dealer
4200-Vehicle shipped
5000-Vehicle delivered to dealer
6000-Vehicle delivered to customer
However, it wouldn't be unreasonable to expect your dealer to check on this once in awhile, like once a week or so.
If they enter the 6-charcter order number of yours, it will return a status event code.
If you are at status code 3000, the "Priority 1" has already done it's job, and may only be relevant for establishing the TPW if your dealer has several orders that are accepted. The priority's primary function is for determining which of a dealer's orders is to be considered first when orders are being selected for production. Establishing priority becomes particularly important when constraints upset the usual sequence during order acceptance.
If you're ordering from a small dealer that occasionally gets an allocation for a Corvette, then ALL his placed orders will be "Priority 1". Most dealers don't bother building orders into the system unless they know they will have allocation. Large dealers will always have some allocation, so they may keep stock orders built into the system at lower priority than customer orders.
From my experience, there appears to be very little "gaming" on constraint issues with larger dealers. They will have other orders they want filled, so if they have the allocation, they allow stock orders to be filled once higher priority orders are by-passed because of constraints. This assumes SOME quantity of the constrained option/feature is available nationwide; if the constraint is ZERO, then no orders are accepted with that constraint.
If a customer's order is affected by constraints, larger dealers with stock orders may keep the customer's order at Priority 1, and simply allow it to remain in the system until the constraints come off. When a dealer has multiple allocations to use every order period, monkeying with or attempting to "game" the system can cause them to maybe lose allocation representing several thousands of dollars in value...big dealers aren't going to take that risk for a single constrained order.
