Build Sheet Question.
Old Aug 12, 2007 | 08:15 AM
not08crmanymore's Avatar
not08crmanymore
Default Build Sheet Question.
Why does it say in the box-top left- MODEL: 07???I have an 05.
Old Aug 12, 2007 | 08:43 AM
novass66's Avatar
novass66
Model number for the car with Chevy,not year of car.
Old Aug 12, 2007 | 11:06 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
As novass66 sez, it's the model of the car, or the body style.
These GM body style numbers go all the way back to the days of Fisher Body. The 07 in the left hand corner says you have a hatch back coupe. In the sixties and seventies, the VIN of every Corvette began with 19437 or 19467; 37 was the predecessor number for a coupe without the hatch back.
Corvette convertibles have 67 in that block; Z06s have still another number that escapes me...I believe it's 01.
Old Aug 12, 2007 | 11:32 AM
Vette_DD's Avatar
Vette_DD
Yep.
1YY07 Corvette Coupe
1YY67 Corvette Convertible
Do you think those folks with an 05 vert thought they were getting a 1967 Vette?
No, it's "1YY87" for a Corvette Z06.
Old Aug 12, 2007 | 02:40 PM
JmpnJckFlsh
Originally Posted by JimTN
:No, it's "1YY87" for a Corvette Z06.
In the context of the OP question, the 1YY portion is superfluous and confusing, since those characters are not shown in the upper left corner box of the build sheet...but, yes, 87 is the correct body number for the Z06.
Old Aug 12, 2007 | 10:51 PM
not08crmanymore
So thats what the 1yy07 in the VIN means!!Thanks for the info!!!
Old Aug 12, 2007 | 10:58 PM
Vette_DD's Avatar
Vette_DD
Now I'm confused.
How did the VIN get in this conversation? I don't think you have a VIN with 1YY07 in it. At any rate, the car model no. does NOT appear in the VIN, AFAIK. A single character appears in the 6th position to indicate the body style ("1" = FRC, "2" = Coupe, "3" = Convertible), but that's all. The model year is in the 10th character position, with a 5 for an 05.
Old Aug 13, 2007 | 01:12 AM
Les-10's Avatar
Les-10
Bow-Tie Guy
knew there was rhyme or reason, thanx
Old Aug 13, 2007 | 01:18 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Not to hijack the OP question, but where can the build sheet be found?
Old Aug 13, 2007 | 01:24 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
The build sheet is normally not delivered to the owner. If you get the NCM delivery it is given to you, or you can order a reprint from the NCM.
Old Aug 13, 2007 | 01:25 AM
mpuzach's Avatar
mpuzach
The original build is attached to the car as it moves down the assembly line. Once the car is completed, I believe the build sheet is removed; thus most owners never see theirs. You can buy a copy of the build sheet through the National Corvette Museum; I bought one for my 2005 and it's actually kind of cool.
Old Aug 13, 2007 | 01:30 AM
Rob 99's Avatar
Rob 99
yes i know about getting it w/museum del i did that with my 04', but my 07' i picked up at the dealer and thought i remember reading here that it's attached inside the car somewere
Old Aug 13, 2007 | 04:24 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
On the C5 the build sheet was put inside the right fender and could be retrieved. Not sure what they're doing with the C6s.
Old Aug 13, 2007 | 06:51 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
No, NCM delivery no longer includes the build sheet but you can buy one there.
To Build Sheet Question.
