i have 2005 C6 and it has 6k miles...if I leave it sit for 3-4 days..battery is dead...I replaced battery and have same problem..I have checked all lites to be sure they are off...has anyone had this problem..??????
Thanks,
Doug
Thanks,
Doug
There have been hundreds of threads about this issue in 05 6spd manuals and other Vettes, Do a search uner DBS.
Quick version this is well know and there is a fix . There is a computer reflash that dealers can do. It takes about a 1/2 hour
Many have had this problem (I did) Make sure you battery is in good condition, all the dead battery knocks the hell out of it.
ADDED
You have low milage for a 05 car, it is possible you do not use it enought to kepp the power hungry items from pulling down your battery.
If that is the case get a battery tender (a lot of us have them) about $20 or so at Wally World. Get a tender not a charger
Reason: ADDED more
I have an '05 I posted relating to my dead battery but that was after the car sat for three weeks unstarted...........your symptoms (if your battery was not drained from one of the dead instances) sounds more like DBS, I was advised that mine was not DBS but merely a dead battery from lack of use...........yours sounds different..........
